C6 Suspension Problem (with pictures)
I hope you guys can help me out with this.
I had a small curb accident recently with my Magnetic Ride control on "track mode". The rear right suspension got damaged plus the rims so I had to change them.
After I had the car fixed, the body alignment seems to be not straight, and traction control keeps on activating which is annoying so I've to turn it off while driving. Noting that I still didn't fix the TPMS sensors to my new rims yet.
You can see the photos below, the rear right suspension is the lowest, and the front left suspension is the highest:
Thank you in advance!
Afterwards, take it to a better alignment shop and have it aligned properly. Ride height adjustments impacts alignment. Obviously that shop was incompetent.
Then set the ride height. Measure from points on the frame not from the body panels. Without looking this up it should be about 4.5 inches rear and 4.0 front ground to frame.
Your TC lights could be anything..broken wire, damaged hub, loose connector.
I agree to find another shop. If you track the car corner weight it and set the alignment to your preference.
Measuring to the body is very inaccurate since GM doesn't specify those measurements or control them. GM measures ride height by measuring the height difference between the lower control arm mounts and the ball joint using a special tool, next best thing is to measure it at the frame shipping slot locations using a tape measure. Ride height varies depending on which version of the C6 you have.GM doesn't publish the numbers for the frame measurements on the C6 but they did on the early C5s which are very similar in construction to the C6s. Those measurements were called the J and K measurements and they are:
J 152 mm (5.98 in); K 157 mm (6.18 in)
I am attaching a diagram to show you where to make the measurements. Make sure the car is on a level surface and then bounce it several times to ensure the suspension is settled before measuring.
If TC is activating that means there is an issue with rear wheel speeds. Either the car is sensing one rear wheel is turning faster than the other or the car is sensing both rear wheels are turning faster than they should be relative to the front wheels. Those things along with no indication of ABS issues mean the wheel speed sensors are operating and the cables and connections between them and the EBCM are working properly. First thing you should do is inspect your replacement tires and wheels to make sure they are the correct size relative to the other tires and wheels on the car. Ratio of tire sizes from front to rear is 1.4. In other words the rear tires need to be 1.4 times the diameter of the front tires. If the ratio is less than that you need to buy two new tires to correct the situation. Did they get the wheels installed correctly? I have seen front and rear wheels swapped by people who aren't thinking they have different diameters. Remember on most cars there is no difference between front and rear diameters so it is easy to do.
Bill
You want to get a combination yardstick-level, to be sure you are using it perfectly vertical. Measure on a flat surface, like a good garage floor. Full tank of gas but no luggage. Tire pressures and tread depth should be equal. Measure, drive around the block, and measure again. And again.
There should be very little difference side-to-side, our car is 0 but many are 1/16"-1/8" different. Front to rear difference is usually 1 1/4" to 1 1/2".
. You need to check everything, since you hit hard enough to warrant wheel replacement. Good luck.
