terrybo
Old Jul 13, 2013 | 07:43 PM
terrybo's Avatar
terrybo
3rd Gear
Default terrybo
Have an 08 that went to reduced power mode and check engine light came on. Hooked up reader and got code PO601. Does this mean the PCM is bad. Anyone else with this problem?
Old Jul 14, 2013 | 10:16 AM
Tonylmiller's Avatar
Tonylmiller
I have no idea, but I had to check out this thread due to the subject.
Old Jul 14, 2013 | 06:40 PM
truckplay's Avatar
truckplay
it means PCM failure. what happened ? dead battery ?
try unplugging the battery letting it set for 30 minutes and reconnecting.
Old Jul 14, 2013 | 08:28 PM
terrybo's Avatar
terrybo
3rd Gear
Put new battery in 4 months ago and keep battery tender on it. Was just driving down the road and engine light came on, then message popped up reading "reduced power", and then engine quit. Started right back up but quit four more times getting it home. Don't know what to do. Will disconnecting the battery fix problem?
Old Jul 15, 2013 | 08:42 AM
Tonylmiller
You will have to tell us if disconnecting the battery fixed the problem.
Old Jul 16, 2013 | 03:32 PM
terrybo's Avatar
terrybo
3rd Gear
The disconnect on the battery did not help. Still shows same code.
To terrybo
