Header and Cam recommendation for a c6z?
Old Jul 18, 2013 | 05:48 PM
rod_racer_stone's Avatar
rod_racer_stone
Navigator
Default Header and Cam recommendation for a c6z?
New to the Corvettes and would like to get some more power from my z06. What are the best header/cam combos for me? I want to make some big power, and not super worried about drive-ability
Old Jul 18, 2013 | 05:49 PM
Erics_02_z06's Avatar
Erics_02_z06
I've got a buddy that is running the Torquer cam, with the Pfadt headers and a CAI and his car is a BEAST!
Old Jul 18, 2013 | 06:52 PM
Gering's Avatar
Gering
Tolero Apto Victum
OP: Welcome to the Corvette Forum, when you get a chance please add your city and state so more members may recommend a good shop as well as mods. Good luck with your upgrades.
Old Jul 19, 2013 | 09:42 AM
rod_racer_stone
Navigator
Martinez California, and looking forward to hearing some ideas! I'm an "Old school" guy and I want a real nasty sounding setup
Old Jul 19, 2013 | 10:29 AM
Pfadt Racing's Avatar
Pfadt Racing
As far as camshafts, vengeance has a camshaft that sounds pretty nasty. You can here it idle it at the end of this little video, its the blue car
Old Jul 19, 2013 | 03:36 PM
truckplay's Avatar
truckplay
"I want to make some big power, and not super worried about drive-ability"
famous last words before you are stuck in traffic with an engine that just WANTS TO GO
your best bet is finding a shop near you or a local club and see what you like.
have you had the heads done on your car ? or are you going to do it at the same time ?
good luck
Old Jul 21, 2013 | 09:34 PM
z0vette's Avatar
z0vette
Pfadt or ARH
For the cam, the striker and BTR ls7 cam
Those are the meanest cams I have seen so far for ls7's
Old Jul 22, 2013 | 04:32 AM
bigterpsfan's Avatar
bigterpsfan
I did a custom grind cam for the street ( 227/243 115lsa) and it sounds terrific. Only had the car back a week and have gotten Aton of compliments on sound.
Idle clip - sounds much deeper and louder in person too.
http://s858.photobucket.com/user/big...d1d97.mp4.html
Old Jul 22, 2013 | 07:20 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
A 'Rumpity Rumpity' cam sound and real performance are two different things.
You know, without the proper heads, compression, displacement, etc, you can over-cam an engine just like you can over-carb an engine.
The 'meanest' sounding cam you can buy will not get you the performance that a cam optimally designed for your engine will give you.
up to you ....
Old Jul 23, 2013 | 05:03 PM
Pfadt Racing
up to you ....
Agreed, you want to make sure that all of your components work together...that is why we don't offer a 2" header to the public...most people will gain much less using a 2" than they would using a 1 3/4 header
Old Jul 23, 2013 | 06:38 PM
VET4LES's Avatar
VET4LES
Make sure you check with your local smog test station on what will pass your bi-yearly inspection. California is tough.
Old Jul 24, 2013 | 01:15 PM
PRE-Z06's Avatar
PRE-Z06
If emissions aren't a factor and you are looking for a max effort gain, then I'd run ARH 2" headers and a custom grind cam based on your desired rpm you want to make power.
To Header and Cam recommendation for a c6z?
