C6 Lowering Kit
Old Jul 26, 2013 | 04:04 PM
xman007's Avatar
xman007
8th Gear
Default C6 Lowering Kit
Hey everyone, this is my first time in this forum and I have to say, it is amazing
I have a 2009 convertible C6
I have installed the lowering kit from Eibach which replaces the spring bolts and tightened the new bolts to the max to get the max ride drop.
I have to say, the car looks ammazing!!!!
BUT, the ride quality is beyond description!!
it is like the springs, shock absorbers, wheels and chassis are all welded together!!!
driving on the high way is a nightmare. the car does not roll anymore on the road, it literally jumps....
Donno what to do
i want to lower the car but I dont want to go for a coil over.
Old Jul 26, 2013 | 04:09 PM
RicK T's Avatar
RicK T
May or may not be your issue but check this discussion for at least one idea of the problem.
http://forums.corvetteforum.com/c6-c...t-warning.html
Old Jul 26, 2013 | 04:24 PM
V8ANGER's Avatar
V8ANGER
Pic!!
Old Jul 26, 2013 | 05:42 PM
xman007's Avatar
xman007
8th Gear
thanks for the eye opener
but my problem is different. tomorrow i will reinstall my stock bolts and check the difference
Old Jul 26, 2013 | 05:51 PM
xman007's Avatar
xman007
8th Gear
is it possible that the cause of the horrific ride quality is that i did not do wheel alignment after i installed the new bolts????
Old Jul 26, 2013 | 05:54 PM
V8ANGER's Avatar
V8ANGER
I think you bottomed out the shocks. Your car must be pretty damn low. It's probably sitting on the bump stops. If you can bounce your car you'll probably see that the tires are flexing and your suspension is not moving an inch.
RicK T's Avatar
RicK T
I don't know how alignment would cause what you described but.......you do have to do an alignment after changing ride height so.....may as well get it done and see what happens. Or wait till you put the stock bolts back then align.
Old Jul 26, 2013 | 06:00 PM
Homer3D's Avatar
Homer3D
Man, does anyone have a good experience with aftermarket lowering bolts?
Old Jul 27, 2013 | 12:59 AM
xman007's Avatar
xman007
8th Gear
you are totally correct. when driving it is like shocks have no give and take at all
as for the height, i was parking next to a 458 Italia and my car is much lower
Old Jul 27, 2013 | 01:02 AM
xman007's Avatar
xman007
8th Gear
i will do the alignment after i install the spacers
Old Jul 27, 2013 | 03:43 PM
xman007's Avatar
xman007
8th Gear
Problem Solved.
installed the original bolts on the rear and tightened to the max without cutting the rubber.
took the lowering bolts, looked for the nearest waste bin and dumped them
To C6 Lowering Kit
