tune
Old Aug 2, 2013 | 07:49 PM
harvey blum's Avatar
harvey blum
Default tune
any ideas as to what the increase in HP would be with a pro. tune on my 2011 gs. thanks harvey
Old Aug 2, 2013 | 08:07 PM
VET4LES's Avatar
VET4LES
You will lose your warranty.
Old Aug 3, 2013 | 07:30 AM
truckplay's Avatar
truckplay
as long as you don't care about the warranty, @ 15-20 hp depending on how agressive the tune and if you change the t-stat.
Old Aug 3, 2013 | 02:52 PM
Boomer111's Avatar
Boomer111
I went from 375/381 to 400/400 with a tune only.
08 LS3 MN6 with 800 miles.
This was with a wheel off dyno.
Old Aug 4, 2013 | 08:26 PM
manic mike's Avatar
manic mike
What does a tune do that would cause you to loose your warranty? What are the other risks to doing a tune besides loosing the warranty? I thought a professional tune was a good thing but I am a new to this.
Old Aug 4, 2013 | 10:59 PM
Boomer111's Avatar
Boomer111
A tune will change the calibrations in the ECM/PCM which ever. Controling air fuel mixture and timing among other things.
Why would you expect GM to warranty the engine after these changes.
From the plant the car is set up run in all different climates and altitudes. A custom tune will zero in on obtaining more performance by dialing in the values for your area and needs.
Basically it just narrows down the parameters optimizing for increased performance.
Usually runs around $500 and a dyno will be needed as well as some time spent on the street with the lap top.
Old Aug 5, 2013 | 01:14 PM
harvey blum
hey thanks for the info. what can I do that wont kill my warranty. I did put on a Calloway cold air induction.Harvey
Old Aug 5, 2013 | 04:36 PM
PRE-Z06's Avatar
PRE-Z06
It wouldn't hurt to get it dynoed to make sure your AFR is still in check
To tune
