Torque tube removal
Old Aug 15, 2013 | 03:19 PM
smplatt's Avatar
smplatt
3rd Gear
Default Torque tube removal
Hello all, new to this forum. I have a 2006 and want to know how to romove the torque tube from the trans. I have it all out of the car and the bolts removed that pair the two together, I even romoved the steel alignment pins, but cant seem to seperate the two. Is there something I need to remove? Thank you
Old Aug 15, 2013 | 03:27 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Pull harder.
Old Aug 15, 2013 | 03:29 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Jokes aside, once you've pulled all the bolts between the trans and rear torque tube bellhousing, they simply come apart. The transmission pulls away from the tube and takes its mainshaft with it, leaving just the exposed female splined end in the torque tube. If all the bolts are out, secure the trans or the tube and rock the other side to side to get a little space between the mating surfaces. From that point, you can get a prybar in there and finish up.
Old Aug 15, 2013 | 03:36 PM
smplatt's Avatar
smplatt
3rd Gear
Ok thanks. Just making sure I wasnt missing something.
Old Aug 15, 2013 | 03:38 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
That said, is this removal for a drivetrain failure by chance? If you bent/broke anything in the trans, there's a possibility the mainshaft is wedged into that torque tube in some sort of shear load, causing extra friction.
Just checking.
Old Aug 15, 2013 | 03:44 PM
smplatt's Avatar
smplatt
3rd Gear
No, no damage. Just breaking them apart to get ready to sell the parts.
To Torque tube removal
