Recently had my car tuned and it made about 397/389 on a mustang dyno. I am debating between going forced induction or going N/A. I have owned blown vehicles and N/A in the past but I am torn on what route to go. I love having that horse power all the time and the lower end power versus building boost to obtain that much horsepower. If I go N/A I will most likely be running a nitrous kit for the track and having that N/A horse around town. My budget is around 6k for this project. What mods are necessary to obtain the 500 rwhp on the GS. Any inputs would be great.
Not sure where you are located, if you are looking to make an honest 500rwhp SAE consider a light weight clutch and lighter wheels/tires in your GS as a healthy cam and 1.875" headers should get you close.
If I had it to do over again, I would do a low boost blower, but it will cost you more than $6K.
The drive ability with a cam that you need to get there, isn't always fun to drive.
I have spoken with you a few times (coilovers,ect) and I believe you were happy with your h/c/i set up at that point? What changed? What issues have you encountered?
Here is a car that Tune Time Performance put together that made right around 500 RWHP on their stingy Mustang Dyno. This was the one of the first shakedown passes. The car went 10.7 at 2200' above sea level. I usually do not like H/C cars but this one drives wonderfully. It is a great package and uses their blower cam.
Later in the season, we took it to MIR and went 10.3 with the same drag pack, front sway bar and passenger seat removed. The customer was extremely happy. Here are to back to back 10.41 runs at 26:47 and 33:10, respectively.
I used to have a 05 and it got totaled. Just picked up a new GS about 3 weeks ago. I don't want a huge cam but a healthy medium size cam would suffice with low lsa.
I've had both. If you do it right, a Cam/Heads/Intake/Headers car is awesome. Like it better than superchaged (ever broke a belt out in the middle of know where?). However do it right. Just don't throw some crappy massive cam at it. Get a cam that is shifted to give good upper mid-range to peak power. Get tri-y headers to get the midrange even bigger. Then use the air intake to keep up with the airflow, and decide how much head work you want to do (obviously you'll do at least springs). Most importantly, use a good tuner. If you do it right, it will be awesome
You can't really stick a huge cam in an LS3 w/o flycutting the pistons on stock heads. It sounds like you'd be happy with a cam that makes good average power as it will be almost as fast as a large cam that makes a high peak dyno number. If that's the case you don't want a low lsa as that increases overlap and narrows the powerband. If you plan to stay NA, then I do recommend the UDP as with the cam idle speed will be bumped ~200rpm naturally and that will offset the difference in 25% reduction with the accessories while still freeing up some power to the wheels. Don't hesitate to call if you have any questions!
Not sure about the specs but it drives beautifully. This car actually surprised us with its N/A performance. Under the right conditions, we believe that a high 10.2 is possible. (Better traction) Not bad for a build that was not an all out N/A setup. Owner is contemplating adding that blower.
Good aftermarket heads like TF add power and their smaller runners tend to help keep the bottom end more livable. Adding a little extra compression helps too. To hit 500 RWHP will not not require a max effort cam with something like a TF 225. Might be tight budget wise if you have to pay for labor.
I have yet to see any cam that consistently gets at least 490 RWHP on stock untouched heads and is considered daily driver friendly.
