Throttle body rotation causing sluggish throttle?
You won't get any better throttle response with any of the aftermarket "boosters", since all they do is change the throttle plate position in relationship to your foot position. All my FI experience (although, none with the Whipple) has shown that from a low engine speed they all exhibit sluggishness when compared to a N/A motor.
It'll work for you. Made my car feel like a different car.
On the late model Throttle bodies, the throttle blade seals on the OPPISITE side of the throttle body opening.
So,,,, Just rotating the TB 180 changes nothing.
I agree,,, you will solve your lag issue with chucks COW BOOSTER mod!
BC
BC
A FI car may run an 11 flat 1/4, but do it with a "sluggish" 1.9 60' time. A booster won't fix that problem.
Standard bet Mortimer?
Absolutely no so. Far too many people know otherwise.
The words..."since all they do is change the throttle plate position in relationship to your foot position." is
totally inaccurate as the key element is that everyone that tries CoW BOOSTER! (and needs it) is a human.
Several ways to explain this, but I always like to explain it in REVERSE.
Several people have suggested..... "Why do I need CoW BOOSTER??? I can just simply press my foot down
MORE on the throttle to get more out of it....."
Fact is....YOU CAN'T. I admit it's a difficult concept to digest, but again....
Better my customers speak for me on this one cause anyone who has CoW BOOSTER! knows
"YOU CAN NOT JUST SIMPLY PRESS MORE TO GET MORE" and if I removed CoW BOOSTER! after you drive it a bit
you would be lost without, and likely hate your car, NO you could not duplicate what I do by just pressing down more....
To the OP: I WILL GUARANTEE you it fixes your problem and YOU WILL LOVE IT or I'll remove it and
return your money to you.
CoW BOOSTER! kicks ***!
Chuck CoW
As a long time respected member and contributor to the forum, and a guy that puts serious miles on his Vette, you should try it. He won't charge you if you don't like it. Knowing you, and having a lot of respect for you, I think you will love it.
I have considered the booster more than once but always come to the conclusion that for my car, I don't need or want a quicker throttle response as I have to pedal it off a hard launch as it is.
Almost as good as my Harley...man that thing with a Carb (my only vehicle so equipped these days) has INSTANTANEOUS throttle response. Downshifting on that thing is musical.
Chuck CoW
So your latest line assumes that two identical cars (one with and one without your booster) cannot perform the same, because the humans can't figure out how to control the foot pedal?
Now just how do you think millions of people who drive all sorts of cars are able to accelerate to a reasonable speed at the same rate and then hold that speed? Well, it's because they press the pedal whatever amount it takes to get the power they need. Some need to press more and some less and they're all human controlled too.
Any way you slice it, the throttle plate on any car will still open exactly the same amount to produce the same amount of power, whether they do or don't have a "booster".
The Booster is more linear so the pedal is more responsive. Stock maps give you less throttle for a given % of pedal, and it "catches up" to 100% open much later in the pedal travel. So the first 50% is lazy, the last 50% is doubly fast. The numbers aren't exact but you get the idea.
The linear feel of the pedal makes a huge deal for us manual trans guys. Probably less of an issue for you automatic guys I'd guess. With a manual you need instantaneous response to a tickle of the pedal to properly heel and toe, if you need to floor the pedal to get a response, you're not going to be able to do it unless you have a double jointed ankle.
It will fix your problem.
