E-brake cable bracket
Old Aug 27, 2013 | 01:51 PM
pablopi's Avatar
pablopi
Default E-brake cable bracket
Hi,
I'm trying to install the rear parking cable on a Z06 knuckle setup but it looks like I got the wrong cable / bracket combination. Basically the cable fitting cannot pass through the bracket hole....
I would need probably a different bracket.
Any help ?
Old Aug 28, 2013 | 10:09 AM
Paratrooper307's Avatar
Paratrooper307
I may not be understanding your problem, but the fitting will only pass partway through the hole. The hole acts as a "stop" for the cable, and when hooked up there will be tension on the spring. I don't know if the Z06 is different than a base, but the construction appears the same. Make sure you verify the part number to be sure.
And while I'm sure you've thought of this, make sure the parking brake is not engaged, or you will find hooking up the cable exceedingly difficult.
