08 z06 tweaking
Old Sep 1, 2013 | 03:52 PM
BJ67's Avatar
BJ67
Default 08 z06 tweaking
I just purchased a 08 jsb z06 with 15000 miles. I am thinking about small tweaks like lowering the t-stat, and bypassing any coolant going thru the throttle body (if there is any) getting into the pcm to let the fans come on earlier like 180 degrees and tweaking the fuel and timing thru a chassis dyno tuner. It already has a k&n air charger. Any thoughts or comments on this subject would be highly appreciated
Old Sep 1, 2013 | 03:57 PM
RicK T's Avatar
RicK T
You'll get some help here but I suggest you post in the Z06 Forum for more responses.
Old Sep 1, 2013 | 04:07 PM
BJ67's Avatar
BJ67
Originally Posted by rick t
you'll get some help here but i suggest you post in the z06 forum for more responses.
thank you for the tip.
To 08 z06 tweaking
