Simple NPP Controller?
Old Sep 16, 2013 | 01:15 PM
jnance50's Avatar
jnance50
4th Gear
Default Simple NPP Controller?
I've done tons of searching both on the forum and off and cannot find an answer to this:
Does anyone make a SIMPLE NPP exhaust controller?
Meaning: I've added NPP mufflers and I don't really care about them opening / closing automatically based on rpm / throttle position / vacuum from the manifold - I only want to be able to open / close them manually on a switch.
I'm guessing this just means a simple vacuum pump that could be switched on and off which would eliminate the need of running a vacuum line off the manifold to the rear of the car.
Does anyone make such a thing?
Thanks in advance!
Old Sep 16, 2013 | 01:30 PM
Wheelman's Avatar
Wheelman
Thats what most of the NPP retrofit kits do. The only one that actually opens via rpm like factory ones is the Exhaust Commander Elite.
Old Sep 16, 2013 | 01:48 PM
jnance50's Avatar
jnance50
4th Gear
Hmm... all the ones I've seen - regardless of the opening at rpm option - still require a vacuum line from the manifold. Can you link to one that doesn't?
I'm trying to avoid having to tap into the vacuum system of the car and run the line as I really don't care about the functionality that would add. It would be a much much easier thing if I could find a controller that supplied its own vacuum - meaning all I would have to do it run switched power to it ... and then its vacuum line to the mufflers.
Old Sep 16, 2013 | 02:23 PM
99NassauVette's Avatar
99NassauVette
Not really a way around this since the entire system operates off of vacuum pressure. The valve on the intake literally "sucks" the valves closed when it's in an off position. You could probably do this with some sort of pump on your own, but I don't see how that'd been economical.
Gabbiani's Avatar
Gabbiani
Don't think there will be a cheap, small, quiet vac pump that can hold them closed reliably.
You could get a mighty vac and run it into the cab. Pump it a couple times for quiet.
I want t o hook a set up with only manifold vacuum and see how it acts. No controller at all.
Old Sep 16, 2013 | 02:49 PM
jnance50's Avatar
jnance50
4th Gear
I've seen Camaros with the ls3 hooked straight to manifold and it does work, it just opens at 50% throttle give or take (vs the Vette 's factory 3500 rpm). Actually I'm pretty sure this is how most aftermarket "Npp in a box" kits work (with exception of the one that integrates into the DIC). They're basically an electric switch that just cuts the vacuum between the engine and exhaust when in "wild" and directly connects the intake vacuum to the exhaust when in "mild". Hypothetically, one could accomplish the same thing with one of these, in the correct diameter of course:
http://amzn.com/B0042HLS3K
Someone feel free to correct me if I'm wrong, admittedly I'm new to this whole Corvette thing.
I've seen someone in the Camaro forum use a vacuum pump and canister off of another vehicle and accomplish what I'm looking to do - I just wondered if someone in the aftermarket had done anything similar. I hadn't however considered the noise of such a pump - perhaps that would be the problem with such a solution.
Still curious if anyone has tried anything similar.
Something like this, mounted behind the tail lamp or in the fender:
http://amzn.com/B0030Z666E
Old Sep 16, 2013 | 04:08 PM
Wheelman's Avatar
Wheelman
I thought they default to open when they aren't connected?
Old Sep 16, 2013 | 04:09 PM
jnance50's Avatar
jnance50
4th Gear
They do, that was my bad, edited for correctness sake.
Old Sep 17, 2013 | 02:00 PM
Bill Dearborn's Avatar
Bill Dearborn
Something like this would be good enough for the vacuum source. You might get by without the vacuum switch if the pressure increases quickly when you switch off the 12V power to the pump.
The vacuum switch would be your best option. Just T into an engine manifold vacuum source and run it to the switch. Then just wire the switch so you can control it with a foot switch in the cabin.
With vacuum routed to the exhaust the mufflers will be quiet until you open the throttle enough to reduce vacuum to the point the muffler valves open which is pretty much the way the stock system operates. You won't get unmetered air into the manifold since the system is sealed if you connect the hoses correctly and your muffler valves don't have any leaks in them.
Bill
Old Sep 17, 2013 | 06:34 PM
haljensen's Avatar
haljensen
The "simple" vacuum pump is ONLY $126.00?
And you still have to run vacuum lines from the pump to the mufflers.
And wiring with a switch and a fuse for power to the pump.
Old Sep 17, 2013 | 08:29 PM
Rajohnson's Avatar
Rajohnson
Default Mild to Wild
Would a mild to wild setup possibly work for you?
Old Sep 18, 2013 | 05:02 PM
weez58's Avatar
weez58
Is it just the act of running the vacuum hose to the manifold that bothers you? I'm not trying to flame you, but my guess is that it took me less time to run the hose than you have spent researching an alternative. The only part that was difficult was cutting the "T" off the vacuum connector on the back of the manifold. I don't think it took more than a couple hours for the total installation.
I have the Exhaust Commander(not the Elite). I love it. Push the button and they open, push it again and they close.
To Simple NPP Controller?
