starter problems
Old Sep 18, 2013 | 06:43 PM
marine&hisvette's Avatar
marine&hisvette
Default starter problems
I fried 2 computers and now I'm testing things. I noticed problem number one, a ground was hooked up to the signal wire post on the starter. Then I'm testing the signal post and wire and they're reading ground (beep with volt meter) before I buy another computer and play yazie with it, is the signal post suppose to read grounded? Also for the aftermarket fuel pump signal wires, I spliced the 2 middle (blue and white) on the fuel pump conector and ran them to the signle posts on the aeromotoive pump.
