Fuel pump question
Old Sep 19, 2013 | 11:27 AM
jrcslc's Avatar
jrcslc
Default Fuel pump question
I have an 08 vert, six speed with about 45K miles. Recently started hearing a high pitched whine from back of car. Took it to the dealer, they also heard the noise and said it was the fuel pump. But recommended I ignore it, because, according to them, it was highly unlikely it would fail anyway.
I was wondering if anyone as had the issue and what you did. Also, any thoughts on the dealers recommendation?
Thanks,
Jim
PS: They said this is a very expensive fix.
Old Sep 19, 2013 | 11:55 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I'd replace the pump. If you are out of warranty, I would find a local shop to drop the driver's side tank and replace the pump with the aeromotive 340 stealth pump. That's what I use with my setup and it works great. The dealer is going to hit you with a ton of labor to drop the tank. It can be done cheaper than they quote and less time. You don't need to remove the rear to get at the tank on the M6.
A squealing fuel pump is a dieing fuel pump and I'd rather fix it than have the POS fail on the highway somewhere while I have the wife in the car.
My $.02
Elmer
Old Sep 19, 2013 | 02:54 PM
jrcslc's Avatar
jrcslc
Thanks Elmer. I agree, don't want the thing to go out while on the highway. I'll start looking for options.
Jim
To Fuel pump question
