Billet-tech alternators
Old Sep 20, 2013 | 05:21 PM
hydbyj's Avatar
hydbyj
Default Billet-tech alternators
for those with alternator troubles such as low voltage at idle because your high amp draw fans are about to take off, the billet-tech alternator is a great product. solidly built and cool as heck looking, uses a 6 phase system instead of three phase in the stock alt. i lost the wiring to my fuel pump, it was melted, and the protect 20 Amp fuse was blown. i was getting service charging system on the dic occasionally so when i heard of this product i did some research. took it up to 210 degrees with the Dewitt dual fan setup running on full, at idle about 800 rpm i was putting out 14.3 volts....far better than the almost 11 volts with the stock alt. good luck to all,
jerry
Old Sep 20, 2013 | 05:36 PM
RicK T's Avatar
RicK T
Thanks for the review. I've been watching for some reviews of this.
Old Sep 20, 2013 | 06:15 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Mine is plodding along at a solid 14.5v and not wavering. I'm used to <14v and sometimes <13v and DIC messages. I've turned everything on that is electronic on the car and it just sits at 14.5v.
I'm happy.
Elmer
Old Sep 20, 2013 | 06:28 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
I'm happy.
Elmer
Elmer,
Did you get the 170 amp?
Old Sep 20, 2013 | 07:12 PM
eboggs_jkvl
Moderator emeritus
Originally Posted by erick_e
Elmer,
Yep, 170 amp chrome.
Elmer
Old Sep 21, 2013 | 05:02 PM
KENS80V's Avatar
KENS80V
How much does the 170amp model sell for if you don't mind I ask?
Old Sep 21, 2013 | 07:23 PM
07MontRedcp's Avatar
07MontRedcp
There is a GP going on right now: http://forums.corvetteforum.com/c6-c...y-is-here.html.
BJK
To Billet-tech alternators
