Squeaky Accessory belt
Old Sep 25, 2013 | 01:28 PM
redgb's Avatar
redgb
Default Squeaky Accessory belt
For a while now, I would here a small squeak from the front end of the motor when first starting. It would only last a very short time.
Anyone had similar problem?Then 10 days ago I replaced the water pump on my 2006 6.0 L engine.
Now there is a squeak coming from the accessory belt or one of the pulleys. I replaced the tensioner pulley and still get the noise.
At idle there is no noise but increase the rpm and the squeak sounds. This noise disappears after the engine warms up.
I wonder if it is the after market belt I used after repacing the water pump. Got it from NAPA.
Old Sep 25, 2013 | 01:33 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I had the exact same problem but replacing the tensioner assembly took care of it. Did you replace the entire tensioner assembly or just the pulley?
Old Sep 25, 2013 | 03:07 PM
EVRose's Avatar
EVRose
Check the harmonic balancer and see if it's wobbling.
Old Sep 25, 2013 | 03:44 PM
redgb's Avatar
redgb
Replaced the pulley only not the tensioner assembly.
Old Sep 25, 2013 | 05:18 PM
batpig's Avatar
batpig
Default belt
I bet it`s your harmonic ballancer.I have an 06 and replaced mine.No noise.
Old Sep 25, 2013 | 05:25 PM
Gering's Avatar
Gering
Tolero Apto Victum
If so, OP, I would recommend you take a look at these two items http://store.katechengines.com/ati-s...ts-v-p230.aspx & http://store.katechengines.com/bille...sioner-p2.aspx
Old Sep 25, 2013 | 07:14 PM
2007SeeSix's Avatar
2007SeeSix
Is that a common thing? Mine wobbles and I'm sure that's where my squeal is coming from. Can GM not put a pulley on correctly??
Old Sep 25, 2013 | 07:17 PM
Gering's Avatar
Gering
Tolero Apto Victum
From what I have read and heard, the OEM part is junk.
Old Sep 25, 2013 | 07:20 PM
2007SeeSix's Avatar
2007SeeSix
Hopefully I can deal with it until I replace it with a better one during a cam swap. I always use a balancer tool to put mine on. I have the Hawk LS tool. Nice product.
Old Sep 25, 2013 | 07:23 PM
Gering's Avatar
Gering
Tolero Apto Victum
Smart move, save on labor time.
Old Sep 25, 2013 | 07:33 PM
truckplay's Avatar
truckplay
did you check the length on the new belt? a weak tentioner can cause it to chirp, but I would suggest you look down to the harmonic balancer while the engine is running and make sure that it is not vibrating (they fail on some cars)
To Squeaky Accessory belt
