Beginner Mods
Old Sep 25, 2013 | 03:03 PM
ryanb910's Avatar
ryanb910
2nd Gear
Default Beginner Mods
I'm about to sell my '10 camaro rs and get a 07 or 08 vette. I know all about modding those but nothing about the corvettes. If you had a 1-2K mod budget on a stock c6 how would you spend it?
Old Sep 25, 2013 | 04:09 PM
Gering's Avatar
Gering
Tolero Apto Victum
Sir,
If you buy the 07 with the "LS2" then I would recommend a FAST 102 Intake Manifold and with either year, I would recommend a set of headers and of coarse a dyno tune. Granted these mods are not cheap, but they will give you some extra HP/TQ without opening up the motor. Good luck with your mods!
Old Sep 25, 2013 | 04:41 PM
hydbyj's Avatar
hydbyj
where are you located? that info will get you to the right professionals in your area to talk to. then you can check them out on the forum to see what other people say about them.
jerry
Old Sep 25, 2013 | 04:55 PM
ryanb910's Avatar
ryanb910
2nd Gear
Im a little less than an hour away from Houston. I see that mods for the corvette are much more expensive than the ones for a Camaro. (I bought headers for under 700, everything ive seen is over 1000 here.) Headers and a cold air intake are in the plan for sure.
Old Sep 25, 2013 | 05:21 PM
Gering's Avatar
Gering
Tolero Apto Victum
OP: Sent you a PM.
Old Sep 25, 2013 | 06:15 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
I would do headers and fast 102 intake. Your stock airbox will flow more than enough to support those mods.
Old Sep 25, 2013 | 06:22 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Originally Posted by ryanb910
I'm about to …get a 07 or 08 vette. If you had a 1-2K mod budget on a stock c6 how would you spend it?
Personally I'd spend the $1-2K to get a 2008, which has the LS3 engine and 30 more HP than the 2007 LS2. Then I'd drive it stock for a while to see if I even want to mod it.
Old Sep 25, 2013 | 08:38 PM
byte_me's Avatar
byte_me
Corsa Xtreme axel back and enjoy that awesome sound!!
Old Sep 27, 2013 | 04:53 PM
brewcitygymratt's Avatar
brewcitygymratt
St. Jude Donor '13
otherwise if 07 or older, headers and a fast 102
Old Sep 27, 2013 | 08:33 PM
05Z51C6's Avatar
05Z51C6
If you end up with an LS2, see my specs below.
2005 LS2 MZ6
Texas Speed 1 7/8 with catless X package - $749
Fast 102 intake - $830
Vararam - $285
Nxt Step axle back - $699
Put down 403/408 with those mods and sounds like a beast.
Old Sep 28, 2013 | 12:55 PM
Mike's LS3's Avatar
Mike's LS3
Find a 2008 with NPP exhaust and you will have 436 hp and 428 ft./lbs of torque, that's 36 hp and 28 ft.lbs of torque more than a 2007. Also, starting in 2008 they were many upgrade changes made including: transmission, steering, interior trim, engine, etc.
Old Sep 28, 2013 | 02:05 PM
ioutrun's Avatar
ioutrun
LG super pro headers with a CAI and tune will start you off just fine. If you have money left still, get borla stingers/atak or B&B bullets as a axle back and you will turn heads with the sound. I would save the $1k for the 102 since it won't be such a dramatic increase in power. You need more mods to really benefit from a 102 intake manifold ie Heads/cams although you will see decent torque gains in the mid rpm range without the H/C.
Old Sep 28, 2013 | 04:29 PM
debo's Avatar
debo
How about the L92 heads and L76 Intake to top that bad boy off? I've seen members get all the parts for around 2k with decent power gains and you can sell your old parts to get some of your money back.
Old Sep 29, 2013 | 02:53 PM
victorf's Avatar
victorf
" I would save the $1k for the 102 since it won't be such a dramatic increase in power. "
^^^Was that based on first hand experience on an LS2?
Historically, axle backs will do nothing significant other than - you're correct - for turn heads purpose!
Sorry!
Old Sep 29, 2013 | 10:46 PM
ioutrun's Avatar
ioutrun
Sorry!
Buddy of mine with a 07 C6 LS2 with headers/full exhaust did a 102 intake and it hurt his dyno numbers in the top end because lot of the extra air wasn't getting used. He did see a decent torque gain mid range though but not much. To really reap the benefits of a 102 is by using it in conjunction with a heads/cam setup. I have buddies with C6Zs that went this route that have a H/C setup and the 102 intake and TB really bumped up gains all across the board after installing and retune
Old Sep 30, 2013 | 09:04 AM
jingle's Avatar
jingle
I'm inclined to agree with the LS3 recommendation - better starting point. After you drive it a while, then decide how to spend. I know that modding is not a necessity for the car, it's a necessity for us...it's something in the bloodstream. My boys talked me into the newer drivetrain and I'm really glad they did. My GS runs very well - I can't wait to violate the factory warranty!
To Beginner Mods
