Injectors and lean codes do they mix?
Old Oct 2, 2013 | 11:27 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
Default Injectors and lean codes do they mix?
If I were to get a lean code for bank 1 and clear that code and then have same code for bank 1&2, clear that code and get a single bank 1 code lean again,
Here is it question.... Could a single or multiple injectors be fouled up (dirty) or fuel not being atomized or sprayed incorrectly.
David
Po171/po174 codes. 93 tier 1 gas always used
Old Oct 2, 2013 | 11:52 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Possible things to check are:
Visually/physically inspect the following items: (check these first)
Vacuum hoses for splits, kinks, and proper connections.
Crankcase ventilation valve and/or system for leaks.
Contaminated fuel.
PCM and sensor grounds are clean, tight and in the proper locations.
Air induction system after MAF sensor for vacuum leaks.
Engine mechanical failure.
Elmer
Old Oct 2, 2013 | 12:05 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Had the same issue a year ago....ended up being an exhaust leak at the header collector gasket causing outside air be monitored by 02 sensor. Causing a lean bank 1 code.
Old Oct 2, 2013 | 12:09 PM
eboggs_jkvl
Moderator emeritus
It'd be nice to know if there are any mods on the car.
Elmer
Old Oct 2, 2013 | 01:08 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Elmer
I think it may be exhaust related bc it does hit a little
Kooks LT HF cats zo6 muff, Fast ported 102 VRCAI ECS TUNE
Old Oct 2, 2013 | 02:18 PM
eboggs_jkvl
Moderator emeritus
I concur, check the tightness and the gaskets.
Elmer
Old Oct 13, 2013 | 12:13 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
Well, it's back. Even after a GM injector cleaner service. My evasive code P0174 is back. I will double check bolts around scavenger section to make sure tight. Any other ideas?
Old Oct 13, 2013 | 07:25 PM
blkbrd69's Avatar
blkbrd69
Gasket is great first bet.
IMHO injector cleaner is just about worthless. May be worth pulling injectors and having them cleaned and flow mapped.
Just did mine with 20K and they picked up between 1 and 4% flow, also a good time to put the fat ones in the back.
Old Oct 13, 2013 | 07:59 PM
truckplay's Avatar
truckplay
that is normally a vacuum leak. clean the MASS and check your clamps.
has the intake manifold been removed ?
Old Oct 13, 2013 | 10:32 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
The intake was replaced >18 months ago with ported102 by Spin. Problems are recent.
How is the safest way to clean the MAF and what brand do you use?
Old Oct 14, 2013 | 12:06 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
As said before, vacuum leak, and clean MAF is where I would start Dave.
Old Oct 14, 2013 | 07:43 PM
truckplay's Avatar
truckplay
go to any auto parts store and ask for MASS CLEANER make sure that it says that on the label. check all the bolts on the manifold. you may still have to SMOKE the intake and check for leaks. a seal on the manifold may have misshapen.
Old Oct 14, 2013 | 08:11 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
I don't think MAF was ever cleaned except when 102 went on. ...........maybe. 125k on clock
Old Oct 15, 2013 | 04:10 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Well, I went and bought MAF and Throttle Body cleaners. Dissassembled from TB to VR. It was dirty on the butterfly, like coated dirty. I wiped inside the TB best I could. Cleaned MAF and reassembled. Test drive......unbelievable, really a hugh improvement...I'm happy
Old Oct 15, 2013 | 04:42 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Good to hear Dave, congrats!
Old Oct 16, 2013 | 09:16 AM
theVcar's Avatar
theVcar
St. Jude Donor '08
Thanks everyone
To Injectors and lean codes do they mix?
