Need some info on corner balancing
Old Oct 12, 2013 | 11:13 PM
Falcon Tech's Avatar
Falcon Tech
Default Need some info on corner balancing
I recently had my 2007 Z06 suspension replaced with Phadt sway bars and a set of Bilstein Coilovers. I also had the car corner balanced because the shop doing the work said it had to be done, when installing coilovers. My question is what is a fair price for the corner balance? I'm sure I got taken to the cleaners but I want to here what others have to say before I tell you the shop that did the work.
Old Oct 13, 2013 | 11:29 AM
CMY SIX's Avatar
CMY SIX
Seems to me it would be part of the job weigh it first and then put the corners back after, not something seperate
Old Oct 13, 2013 | 12:36 PM
07MontRedcp's Avatar
07MontRedcp
I installed my own coil overs and then got an estimate for a corner balance from a local speed shop that also is a forum vendor. The quote was $300.
BJK
Old Oct 13, 2013 | 02:02 PM
Falcon Tech
Wow 300.00 I wonder if that about the normal rate. I got stuck with $1500.00. Yes I said $1500.00. For corner balancing only. Of course I paid for the coil over install on top of that. Needless to say I will never visit MTI Racing again.
Old Oct 13, 2013 | 02:12 PM
timd38's Avatar
timd38
I was quoted $2 to $300 also.
Was the $1,500 for the install of all the parts along with the corner balancing, if so it is still to much.
I did the Pfadt kit in my garage in 5 hours and never did it before, so at $100 a hour plus the $300' plus misc stuff. $1,500 sounds like a bit much.
One more thing, an alignment could add a couple hundred to the job.
Old Oct 13, 2013 | 02:17 PM
Falcon Tech
Corner balancing only. Install was like 400.00
Old Oct 13, 2013 | 02:21 PM
vette6500's Avatar
vette6500
I never did corner balancing on my car, but...
Old Oct 13, 2013 | 05:21 PM
CMY SIX's Avatar
CMY SIX
I'd be calling the BBB
Old Oct 13, 2013 | 05:32 PM
Boomer111's Avatar
Boomer111
Oh my God.....I'd call them out in the thread too!
At my shops rate that is near 15 hours work.....they saw you coming on this one.
Old Oct 13, 2013 | 05:39 PM
Brandon619's Avatar
Brandon619
Wow, $1500 is a direct rip off MTI should be ashamed of themselves. You can buy a four corner scale set up for close to that price. I can't even believe that they would even try to charge you that.
Old Oct 13, 2013 | 05:51 PM
Falcon Tech
Yea the sad part is this was a friend deal and when I called them out on it, per MTI they called several shops and were in the ballpark. I had some other work done by them at the same time total bill was just over 13k. Got Vengeance Racing to quote the same work and parts install and guess what 9800.00. Yep over 3k difference and MTI didn't even try to explain except they are priced where other shops are priced at.
Old Oct 13, 2013 | 07:13 PM
haljensen's Avatar
haljensen
Both my '05 and my '08 were checked for corner weight, $40 to check with an alignment. If I would have had adjustments made it was $80 an hour till I was satisfied with the balance.
The corner weight had to be checked and if need be had to be done before the alignment since changing corner weights is done by adjusting ride height and changing ride height changes alignment.
Old Oct 14, 2013 | 10:25 AM
CMY SIX's Avatar
CMY SIX
I like the people at Vengeance racing
Old Oct 14, 2013 | 12:43 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
Falcon Tech,
Look up how to corner balance. Its just a matter of using a wrench to loosen or tighten each coilover perch.
Soooo simple. After U see a video. U will realize an hours work is not worth $1500.00 bucks. Even if it takes them 2 hours. that is 750 an hour.
Stop the payment !!!!!!!!
Robin
Old Oct 14, 2013 | 05:21 PM
MTI RACING's Avatar
0MTI RACING
Former Vendor
Default Chassis Setup
The $1500 MTI charges to install coilover's is not just corner balancing. When we install a coilover suspension it includes coilover installation, ride height adjustment, corner balancing, and alignment. To get the proper ride height you make an adjustment, measure, drive car, measure and make adjustment, repeat, can be very time consuming. In no way did MTI Racing to overcharge or take advantage of Falcon Tech.
Old Oct 14, 2013 | 06:40 PM
timd38's Avatar
timd38
Looks like we got the answer!
Old Oct 14, 2013 | 06:51 PM
haljensen's Avatar
haljensen
The OP claims in two different posts that the corner balancing was separate and and that he paid full price of $1500 just for corner balance + more $$ for installation (and parts?).
I need to see an invoice to prove who paid how much for what.
To Need some info on corner balancing
Old Oct 14, 2013 | 07:00 PM
Brandon619's Avatar
Brandon619
OP is this possible to post the invoice with your personal information blacked out?
Old Oct 14, 2013 | 07:05 PM
timd38's Avatar
timd38
MTI could not be as successful as they are by taking advantage of people. If you start to do the math on what they are doing for $1500, it appears fair to me.
Getting the ride height and alignment correct takes time, and time is money.
Old Oct 14, 2013 | 08:56 PM
Falcon Tech
Ok my bad part of the 1500 was to install the coil overs so 2 hours on that and the rest for the chassis set up. Does that not seem high. OK so the alignment there was no mention of that on the invoice but ok 75.00. So my math 200 for coil over install even 300 at the high end 75.00 for the alignment and 1125 for the chassis set up. So far who thinks this is reasonable. I have attached the invoice for you all to see. You tell me if this is reasonable or not.
File Type: pdf
