Batt Tender
Old Oct 22, 2013 | 08:46 PM
steve9107's Avatar
steve9107
Default Batt Tender
Powered up my Vecter 1/2 amp battery tender on my 07 Coupe last week. Today I found the tender making a rapid "clicking" or rattling noise along with both green and amber light glowing. This condition continues for about 30 seconds - then only green light glows. Then the tender repeats the above.
I connected the red clamp to + battery terminal, the - on an exhaust manifold bolt.
Does anyone have a clue what is causing this?
Old Oct 22, 2013 | 10:05 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The only things I can think of are:
Bad connection to battery/car.
Bad wire to or from tender.
Defective tender.
99% of the time when I have a problem, it's #1.
Once in 30 years, it was #2.
Old Oct 23, 2013 | 09:32 AM
steve9107's Avatar
steve9107
Thanks GJ.
Old Oct 23, 2013 | 09:42 AM
4SUMERZ's Avatar
4SUMERZ
Why wouldn't you want to connect tender to (+) and (-) of battery.
Try that first to see if the tender does the same thing. If it does, maybe the tender is going bad.
Old Oct 23, 2013 | 05:03 PM
saplumr's Avatar
saplumr
I guess I'm not sure what the reason would be for not connecting the negative clip to the battery anyway.
Old Oct 23, 2013 | 05:35 PM
Gearhead Jim
St. Jude Donor '13
I think the idea is that you can get a spark from the connection, and a charging battery gives off hydrogen gas.
We are supposed to connect positive to the battery, then negative to a ground somewhere else so any spark will be away from the battery. I will plead guilty to not always doing it that way.
Old Oct 23, 2013 | 08:37 PM
steve9107's Avatar
steve9107
Right GJ, instructions for the tender call for - connection away from battery.
I removed the negative connector from the exhaust manifold bolt, cleaned the bolt head with sandpaper. I did notice a bit of surface rust - not much (I cleaned the bolt head last year). After applying a little oil on the bolt head to prevent further corrosion I connected the negative clamp and powered up the tender = working fine. I didn't think corrosion would be an issue as I cleaned the bolt last season and never drive in the rain, but I see humidity is a factor. From now on I'll clean the connection every season.
Thanks guys.
Old Oct 23, 2013 | 08:57 PM
saplumr's Avatar
saplumr
I don't know about the rest but Deltran battery tenders show connecting directly to battery terminals.
To Batt Tender
