ZO6 calipers and rotors will bolt on with the use of ZO6 brake lines. The problem is that your wheels probably will not work with out spacer's so they will clear the caliper's. Stock Gumby wheels will work with a 10MM spacer, some aftermarket wheels will work with no spacer--Ace Slicks and some TSW models come to mind. Most of the time if you use a spacer you will have to install longer wheel lugs or some people use extended thread lug nuts. Search ZO6 brakes on a base in the General Discussion and the Tech section for lots of info and opinions. Many have done the swap with no problems.
Awesome thanks!!
My car already has Z06 wheels, so clearance should not be a problem.
I also plan on upgrading to SS brake lines.
If the wheels are real ZO6 wheels--width and offset for a ZO6--you will be okay. If they are replica ZO6 wheels made for a base with base sizes and offset I don't think they will work, but I am not sure. If they are real ZO6 wheels on a base they must be sticking outside of your body work because they are made for the wide body ZO6 fenders.
IIRC the stock C6Z wheels will protrude 45mm over the base wheels in the rear -- that is a lot. If it's done, no way the car can be lowered and I think on hard cornering the rears would rub, badly actually.
Maybe someone here has this set up?
10mm spacers should be okay... I'd like to explore the Z06 brakes as well.
