Ranger Method Clutch Fluid
So I utilized the ranger method and cleared the reservoir maybe or 8 times pumping clutch 50 times between siphoning out fluid. After that the fluid was relatively clear but then I went for a short 5 mile drive when I returned my fluid was filthy again. Is this normal and it takes a few times to actually get it to remain somewhat clear? I just purchased this car it has 20000 miles 2009 C6 Coupe and the fluid looked like Coffee you get while aboard Navy Ship. Which is why I immediately executed the ranger method.
I did my 08 from the nearly the start and in the beginning it took only two exchanges to get it clean. I do it whenever I think of it now, maybe every 1500-2000 miles and it is always clear.
It would seem that your fluid was neglected and might take more exchanges to rid the fluid of the seal containments.
I will say though that 8 times is the most I have read on this forum and still have dirty fluid. Most usually take 1-4 times the latter if dirty and neglected some.
I gave up on the Ranger method after several tries.
http://www.tickperformance.com/tick-...rvette-c6-z06/
Our Tick Performance Adjustable Clutch Master Cylinder Kits are built here in the USA around Tilton 7/8” Bore Cylinders (the same used in NASCAR every Sunday) and are made adjustable so that you can tailor the amount of fluid that your system needs in order to fully disengage ANY clutch, from stock to hardcore race-only clutches. With our kit installed, you’ll notice:
A slightly stiffer (we normally see ~15%), shorter pedal (in most cases) due to the increased cylinder bore
A clutch pedal that is easier to modulate with a predictable, constant engagement point
Effortless shifts at any RPM (especially high RPM), even when driving extremely aggressively
Longer clutch & transmission life as a result of a properly-disengaging clutch
Multiple other issues and annoyances fixed, including the infamous “crashed pedal”
Every Tick Performance Adjustable Clutch Master Cylinder Kit ships complete with everything needed to install, including our Unrestricted and Heat-Wrapped Stainless Braided Clutch Hydraulic Line (eliminating the need for the "drill mod"), all necessary hardware, and easy to understand instructions. Installation generally takes 90-120 minutes (minor drilling required) and adjustments can be made at any time without any tools.
Tick Performance Adjustable Clutch Master Cylinder Kits are capable of more fluid flow than any competitor’s offering, and we stand behind them with a LIFETIME Warranty against leakage. Rest assured that with our kit installed, you'll have the quickest shifting, most reliable kit available under your left foot!
To Download the Instructions for TAMCKYBC6, please right click here and "Save Link As"
To Download the Supplemental Instructions for Longer Length line, please right click here and "Save Link As"
Option Guide: Do I need the Shorter Line, Longer Line or Both Lines?
Our kit in it's basic form includes the Heat-Wrapped, Stainless Braided "Short Line" and DOES NOT require removal of the transmission. If you want to eliminate the bulky OEM quick disconnect fitting and the factory steel & expandable rubber line that connects to your slave cylinder, our "Long Line" is a Heat-Wrapped, Stainless Braided full-length line that couples our Master directly to your stock slave cylinder. This line provides the best, most unrestricted connection, but requires transmission removal to install. If you don't want to remove your transmission now, but plan to later, you can order the kit with both lines. Don't forget our Remote SPEEDbleeder Line while you've got the transmission out (sold separately!)
Bleeder link.
http://www.tickperformance.com/tick-...maro-firebird/
Bleeding the late model GM hydraulic system in it's stock form is a bear. You've got to have someone pump the pedal while you're under the car cracking the bleeder and hoping everybody's timing is right - not to mention keeping the reservoir full! It's easy to see how something so simple can quickly turn into a huge ordeal.
With our "One Man Job" Remote Clutch SPEEDbleeder Line, Tick Performance is taking great strides in making things much easier on you. At 4'+ in length, you're able to route the line to nearly anywhere on the car you want. Here in house, we usually zip tie it to a brake line coming out of the brake master cylinder so it's easy to reach with the hood popped. Another huge improvement is our SPEEDbleeder end - allowing you to simply crack it open one time and close it once the air is out of the system, instead of having to open and close the bleeder with every pump of the pedal.
Why hassle with your hydraulic system every time you want to bleed it? Rely on Tick Performance to make the job much easier for you with our "One Man Job" Remote Clutch SPEEDbleeder Line. A must-install next time you've got the transmission out of your LS1 Camaro & Firebird, 97-04 Corvette & Z06 or 04-06 Pontiac GTO.
Initially the brown is stain from the seals and then its actual contaminants so yours might have been really bad...
It really helps the shifting by the way....
I started doing mine when the car was new and it took two or three months of weekly changes before it stayed clear for any long period of time. Now, seven years later, it takes about six months of driving before it starts to darken.
Do like couple other member suggested, siphon the fluid - drive and repeat. It might take 1000 pump cycles but no wasted wear on the seal.
I patiently did that initially and fluid eventually cleared up - it does not stay 100% clear due to seal wear, but only need occasional change to keep it relatively clear.
everytime I drove it for about a month, I changed it; now I only have to do it maybe once a month and even at that, its pretty clear.............fluid is cheap and its easy to do, so im not worried about going overboard...........
I am easy on the clutch but and I do practice engine braking.
