Battery tender usage question
Old Dec 7, 2013 | 04:53 PM
ghostmech's Avatar
ghostmech
Default Battery tender usage question
Those who use these tenders and don't drive your car on a regular basis, do you keep it connected all the time or do you just do it periodically to bring the battery back to full charge?
I've been doing it the latter, but am starting to just leave it on all the time...any possible problems with this or is this what most do?
BTW, I'm using a Ctek tender
Old Dec 7, 2013 | 07:59 PM
saplumr's Avatar
saplumr
I leave mine on for 5 months straight in the winter.
Old Dec 7, 2013 | 08:28 PM
GMJim's Avatar
GMJim
I leave mine on two cars connected for 5 months at a time as well. Have been doing that for years. Battery Tender is designed for that.
Old Dec 7, 2013 | 08:55 PM
jft69z's Avatar
jft69z
Same here, leave the Cteks on the cars continuous, no problems.
Old Dec 8, 2013 | 09:00 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I leave mine on the vette, tractor, and ZTR continuously.
Old Dec 8, 2013 | 09:09 AM
truckplay's Avatar
truckplay
I only get to drive my car once a week, less as of recently I plug it in as soon as I close the garage door.
Old Dec 8, 2013 | 10:38 AM
ghostmech's Avatar
ghostmech
Do you find it will recycle thru the various stages of charge as time goes on? I left mine on all day and thru the night, checking it periodically to see the speed of charge rate and what happens for a long period of time after it went green (full charge). Sometimes it would cycle back to 3/4 charged and eventually back to full. This morning it was back down to the lowest battery level (as if the battery were low and the charge sequence was just starting out again). Is that normal?
Old Dec 8, 2013 | 11:24 AM
GMJim's Avatar
GMJim
There is a micro processor in the charger that conditions the battery. At no time have I experienced the charger letting the battery get to a low then recharge state. I spoke with the Battery Tender/Deltran guys at a car show not long ago and they basically told me that the Tender keeps the battery in a better state than in the car.
Old Dec 8, 2013 | 12:14 PM
ghostmech's Avatar
ghostmech
Thanks Jim.
Hmmm...Then I must assume the what is happening with my Ctek is not normal. To go from fully charged/almost charged to the next morning where it shows low charge.
Old Dec 8, 2013 | 12:19 PM
Tonylmiller's Avatar
Tonylmiller
Thanks Jim.
Yeah, you might have a bad battery. I have been out of town for two weeks and it started right up when I returned. No tender.
Old Dec 8, 2013 | 01:31 PM
GMJim's Avatar
GMJim
Thanks Jim.
I'm not sure how the Ctek works? I can only assume it's supposed to work the same as the Battery Tender. I would pull the battery and have it tested to make sure it doesn't have a bad cell or something else wrong with it.
Old Dec 8, 2013 | 06:14 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
OP-
The CTEK's (and probably some of the other brands) are supposed to sometimes go through a cycle that's supposed to "de-sulfate" the battery or something like that, could that be what you saw? My CTEK manual tries to explain it, but I think something got lost in going from Swedish to English.
Old Dec 10, 2013 | 05:52 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
My Battery Tender + goes on my vehicles whenever they are in the garage (I have one for each vehicle). Once the green light comes on, it stays on. I have never seen either of my tenders go back to red after being on green. The only thing that will get a red restart is disconnecting and then reconnecting the tender.
To Battery tender usage question
