Will the C6 Z06 exhaust manifolds bolt up to the C6 2005's LS2 correctly? Thx
Yes. You'll need C6 Z06 cats and midpipe also. Then you'll either have to get Z06 over axlepipes/mufflers, after market Z06 mufflers or cut and weld your stock mufflers.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
If you have the M6 then it is a true bolt on swap you can install the entire Z06 exhaust from exhaust manifolds to the mufflers. The A4 will take some instant modifications to fit
If you do a search you will find many threads regarding installing the exhaust on the A6.
The problem areas are:
1.) spreading the mid pipe to fit around the trans
2.) fitting the 3" inch pipes around the trans
3.) Keeping the heat away from the various lines & etc.
Thanx for the link but I'm still looking for some photos of a stock install ZR1 or Z06 system on an A6.
