I bought my C6, 2008 Z51 M6, with 32K miles. Clutch fluid was black. The car currently has 37K miles and I have changed the clutch fluid twice using the ranger method. Although I've changed it twice in the past 5K miles, I can't seem to keep the fluid clean. It seems it turns black almost immediately after changing it. When using the ranger method, I am pumping the clutch and repeating the process until the fluid is completely clear.
I noticed today while rowing the gears it seems like my shifter got a little mushy and my pedal lost a tad bit of firmness while running high in the RPMs. I would like to keep the clutch fluid clean to help clutch life.
So is it normal for that the clutch fluid needs to be changed this often?
Yes and no.
It depends on how the vehicle was driven and how the clutch was used.
The ranger method is easy but if your not carful you could induce air into the system that would require a proper bleed (via the slave cylinder). The unfortunate part is that in order to bleed the slave on a stock system you will need to to remove the stock H pipe and tunnel plate.
I hope this helps.
The woodlands Texas.... We are building a 600HP 383ci LS6 1981 Corvette for a customer that lives in The Woodland, Texas. Small world.
Not sure that anything needs to be done that often to increase clutch life. I have owned two C5 and one C6 manual cars since 1997. The 97 never had its clutch fluid bled, the 03 only had it bled once when I had a failed pressure plate replaced, and the C6 was bled twice in the last 4 years. Once when the engine was replaced and I had a remote bleeder installed and then two years later when I decided I might as well use the bleeder and bleed the clutch. When I did that I ran about 7 ozs of Pentosin Super DOT4 fluid (GM Recommended Fluid) through the hydraulics until the drained fluid ran clear. It took several months for the fluid to turn dark again.
A clutch that is slipped more is going to produce more dust which is going to contaminate the fluid faster ie if you do a lot of stop and go driving it's going to get dirtier quicker compared to cruising on the highway. IMHO the car should have come with a remote bleeder to properly bleed the clutch easier with the inherent design of the slave being in the bellhousing.
Just keep changing it via Ranger method and drive it. It will take many changes before it starts staying clear for any period of time. I changed mine about once a week for the first few months of my car's life before it started staying clear. Now, after seven years of use, the fluid stays clear for many months and I only have to change it about twice a year.
One thing to keep in mind, seal will wear, even under normal operation from each clutch paddle stroke.
That said, I also use the Ranger's method. But only the siphon part. Then refill, drive the car and allow the contaminated fluid migrate through. That will take time and patience, but will get the job done eventually, all without causing unnecessary premature wear to the seals.
***With the current design, I would be weary of suggestions from anyone - questioning the need to change out the clutch fluid to extend clutch life.
