Diffuser performance
Old Feb 8, 2014 | 05:17 PM
rabrooks's Avatar
rabrooks
Ok, I got around to developing the new diffuser shape and here it is. Its an average of 14 degrees but the main suction point is at 11 degrees. The ramp is gradual and then there is more shape at the exit. This shape should prevent boundary layer separation and improve drag coefficient due to the shape helping reduce turbulence in the license plate area I should have taken a pic of the pattern as its in the right side up orientation. It would've been easier to tell what's going on. Maybe I'll get that tomorrow
Cheers
Old Mar 2, 2014 | 07:33 PM
rabrooks's Avatar
rabrooks
Got around to priming, sanding and waxing the new foil shape. I have applied two layers of structural fiberglass. I'll pull the fiberglass foil off tomorrow. I won't get to fit it to the car as I'm going to Florida for a week on business. But when I get back, I'll be fitting it and completing the final shape.
Pics tomorrow
I was able to pick up a used factory diffuser for $100 to help me shape the portion that attaches to the car. Thanks KNS Brakes
Old Mar 3, 2014 | 07:35 AM
el es tu's Avatar
el es tu
Old Mar 3, 2014 | 08:59 AM
timd38's Avatar
timd38
So you are using the wood to make a mold, correct?
Old Mar 3, 2014 | 10:10 AM
rabrooks's Avatar
rabrooks
No, I'm using the wood to make the plug. That is the pattern the mold is made from. The fiberglass part I just made (pics coming) will be a dummy part that allows me to fit it to the car so all the fitment is correct. I'll transfer that to the wooden part before I make the mold from the wooden part (plug)When we do this type of work, you have to think completely inside-out. It often helps to be dyslexic
Old Mar 3, 2014 | 10:18 AM
timd38's Avatar
timd38
OK, I just didn't know the terms. Sound like a great project!
Old Mar 3, 2014 | 09:08 PM
rabrooks's Avatar
rabrooks
Here are the pics of the new fiberglass foil shape removed from the plug. This will become the part fitted to the car, and then all the mods made to it initially and then transferred to the plug.
Old Mar 24, 2014 | 08:38 PM
timd38's Avatar
timd38
Any pictures of the completed project?
Old Mar 24, 2014 | 09:32 PM
rabrooks's Avatar
rabrooks
Not yet. I have been struggling with other projects and a cold winter. But it will move forward. Its just going to take time as I'm not as young as I once was. I'll keep the thread up to date as it happens. Thanks for looking in.
Cheers
Old Mar 25, 2014 | 09:34 AM
timd38's Avatar
timd38
In your 20's, you will do most anything
In your 30's, most things aren't bad to do
In you 40's, you wonder why you are doing it
In your 50's, you ask, how much will it costs
I am going to be 60 this year, so I had to add one for being 60.
In your 60's, you ask, when can you do it.
Old Mar 25, 2014 | 10:10 AM
rabrooks's Avatar
rabrooks
Too funny. My friend's grandmother lived to be 98. She said getting old wasn't for sissy's. lol
Old Mar 26, 2014 | 12:39 PM
Mr.Nubain's Avatar
Mr.Nubain
From: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
Originally Posted by Kadorja
FWIW I've been 185 in my car and had no issues with the rear downforce. The front of the car gets a little light but that was more of the poor road condition and suspension setup. I myself and more concerned with the front of the car than the rear.
I couldn't imagine how fast that would feel. I've gotten to near 130 and the car felt like it was floating. My C5 was very unstable at high speeds like that.
Old Mar 26, 2014 | 03:15 PM
  #33
rabrooks's Avatar
rabrooks
It probably wasn't as light as you think. I expect your not comfortable going fast or you haven't gone fast alot. My C5 convertible was fine at top end. However the hardtop and the vert were better aerodynamically than the coupe
Old Mar 27, 2014 | 05:57 PM
  #34
Mr.Nubain's Avatar
Mr.Nubain
That is true
Old Apr 5, 2014 | 06:44 PM
  #35
rabrooks's Avatar
rabrooks
Finally got a chance to fit the new foil shape to the car. it's a rough fit but I'm happy with where I can go with this so far. the first pic is the factory diffuser cut away. Thye second pic is the new foil in place against the factory diffuser. I'll meld the two together then make the mold. the vertical plates will come later. They will be a separate build as added after the main part is built. the new foil goes forward all the way to the fuel tanks
Old Apr 5, 2014 | 10:37 PM
  #36
timd38's Avatar
timd38
Have you looked at the APR one that goes to the front of the diff?
I am not as talented as you so I ordered one last week.
Old May 27, 2014 | 08:59 PM
  #37
rabrooks's Avatar
rabrooks
Update: Here is the foil with all the correct holes, slots, etc. The exhaust area will be a blown double decker diffuser, but only where the exhaust is. the rest will be a single foil diffuser. I am going to VIR with this on Friday. My goal is to see what the diff and trans temps get to. Then I'll have a better idea about how to address the rest of the design. After the track trial, I'll add the double foil and the strakes, that is if all goes well.
Cheers
Old May 27, 2014 | 09:28 PM
  #38
rabrooks's Avatar
rabrooks
PS: I widened the foil to extend outward to get closer to the wheels and to cover as much of the A arms as possible. This will allow me to add a strake to the underside that will redirect and clean up the air going into the wheel itself.
The notches at the top of the foil are the cut outs for the rear of the fuel tanks
Here is a rough sketch of the final product if nothing changes from now til the end
