I have a 07 c6 ls2 and am looking to go with a fast 102 for my 1st mod on my newly purchased\first time ever owning a vett. I was wondering what all do I need for the fast 102 as far as support mods and parts. Also I'm not planning on doing this until summer, where is a good place to get this from. I've found numerous site that have them. And what parts do I not need that they try to sell you?
Most sites will tell you what you need for what year. I think its the ls3 that need a fuel rail or fuel rail spacers because they have shorter injectors. Just look for the best deal and or pm some of the vendors if no one has already pm'd you. I usually see em in the $8-900 range.
And put money aside for a tune.
Pretty sure it is straight up install for an LS2. LS3's will go to the LS2 style fuel rail. Plan on doing headers as well. All that air in needs to get out. Maybe do Fast and Headers then get a tune. Why pay for 2 tunes. I went the other way. I did headers and full exhaust first (also did a cam) and now going to do the fast 102. Good Luck
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
It is a great mod for the LS2 and you can stick with your stock fuel rails. Here is a picture of mine. I am planning the fuel rails just for the look, but it does nothing for the performance (the fuel rails - the FAST did plenty)!
Unless you plan on going to a 102 throttle body, I believe FAST now has a 90 that matches the 90 mm throttle body on your car and should work just as well.
