Z06 Brake Conversion
Old Jan 4, 2014 | 07:30 PM
TurkeySlugger's Avatar
TurkeySlugger
Default Z06 Brake Conversion
Has any one who has done this conversion on a base had the issue with the brake lines not fitting the stock brake line fittings and the install to be a complete pain in the ***? I had to go out and buy new fittings for the brake lines cut the old ones off and redo my brake lines. I almost had to put new brake lines on my car and I only did the rear. I have to wait for my jack pucks to get in to do the front.
Old Jan 4, 2014 | 08:12 PM
timd38's Avatar
timd38
Do your wheels fit?
Old Jan 4, 2014 | 08:25 PM
TurkeySlugger
Originally Posted by timd38
Do your wheels fit?
Yes running 19 and 20 with ZR1 wide body conversion
Old Jan 5, 2014 | 03:22 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Next time use a Thread File to clean the threads. It seems that more than a few line-to-hose connections were tighten by Superman and buggered the threads.
You don't need jacking pucks to jack up the car, on either end
Old Jan 5, 2014 | 11:37 AM
TurkeySlugger
I was thinking the same thing so I took both the stock line and the goodridge line to an auto parts store and had that check. They were two completely different thread patterns. I cant remember what stock was but the new lines were 3/16th. My lines were brand new in box with z06 on the box. It was a nightmare but got the rears on and now not looking forward to doing the front.
Old Jan 5, 2014 | 01:56 PM
SUCAMILLA U 427's Avatar
SUCAMILLA U 427
Just buy some hockey pucks.
Old Jan 5, 2014 | 01:57 PM
glenB's Avatar
glenB
I used Goodridge and had no problems.
Old Jan 5, 2014 | 02:10 PM
timd38's Avatar
timd38
Did you buy the car used? If so, you have no clue what the previous owner/s did.
They may have changed the lines to something else.
Old Jan 5, 2014 | 02:13 PM
TurkeySlugger
I thought about it but didnt feel like messing with it at the moment
Old Jan 5, 2014 | 02:14 PM
TurkeySlugger
Yep im the 6th owner. if that is the case then why do the stock brake lines fit the fittings on the lines?
Old Jan 5, 2014 | 02:25 PM
timd38's Avatar
timd38
Are you using Z06 lines?
If not are the Z06 brakes and lines new? If not, maybe the previous owner did something that is causing you pain.
I am not a fan of Z06 brakes, so I bought Wilwoods and everything fit fine.
Old Jan 5, 2014 | 02:33 PM
TurkeySlugger
They are Z06 brakes and Z06 lines. Lines brand new and the brakes have about 1500 miles on them.
Old Jan 5, 2014 | 02:47 PM
timd38's Avatar
timd38
No more ideas at my end.
Let us know what you do.
Old Jan 5, 2014 | 02:53 PM
TurkeySlugger
the rears are on and good to go now, but had to put the new fittings on the lines. and had to re-bend one of the hard lines to get the fitting to get far enough back to get the flare tool on the line so i didn't have to put a whole new hard line on. only took like 9 hours to do just the rears lol
Old Jan 5, 2014 | 02:56 PM
vettenutchas's Avatar
vettenutchas
I also used Goodridge ZO6 lines with no problems, maybe you got the wrong lines from Goodridge?
Old Jan 5, 2014 | 03:19 PM
TurkeySlugger
I thought that as well but the box they came in says Z06.
Old Jan 5, 2014 | 08:40 PM
eboch's Avatar
eboch
Hi;
I did a conversion of a 2005 Z51 car using 2008 Z06 stock brakes and lines. My Z51 car has 18" fronts and 19" rears. The 18" fronts are needed to clear the Z06 calipers.
Brake line fittings fit perfectly ... a little cramped in terms of wrenching, but otherwise I didn't encounter any thread-mismatch issues between the Z51 and Z06.
You will need Z06 rotors. Z06 rotors are larger diameter than stock rotors or Z51 rotors. Take care to find the right size Z06 rotors (355mm front, 340 mm rear) ... I found a lot of vendors sell "Z06" rotors ... but their diameters are smaller than true Z06 rotors.
One other thing ... be careful of wheel hub offsets. I had to build 1/8" spacers for my rears because they didnt quite have enough spoke offset to clear the Z06 calipers (even though they are 19" wheels. Wheels designed for a base C6 or C5 may not have spoke designs that can clear the additional thickness of the Z06 caliper (i.e. there is more to consider here than just the wheel rim diameter).
The base corvette, Z51 corvette and Z06 share the same wheel bearing brackets ... so there are no changes required or brackets to change .... the various GM stock C6 calipers simply bolt in (i.e. the caliper itself accommodates the different rotor diameters).
Good luck.
eboch
To Z06 Brake Conversion
Old Jan 5, 2014 | 08:51 PM
TurkeySlugger
Originally Posted by eboch
Hi;
Good luck.
eboch
Im running ZR1 wheels so thats not an issue and the brakes are OEM Z06 brakes and rotors off a 09 Z06. I dont know what the issue is.
Old Jan 6, 2014 | 10:52 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
I had the same problem when putting ZO6 brakes and lines on my '05. Had to re-shape the threads on the brake lines with a file to make them work. Over tightening at the manufacturer/factory was thought to be the problem.
Old Jan 6, 2014 | 03:42 PM
TurkeySlugger
I thought that may had been the issue at first, that's why I took both the stock line and new line to have the treads checked and were two completely different thread patterns
