LS2 rods and piston help!
Old Jan 7, 2014 | 12:29 AM
sick cc's Avatar
sick cc
Default LS2 rods and piston help!
guys I need to find a set of rods with a 6.098 C to C and a .945 wrist pin diameter. what I found so far is eagle H beam, 6.100 stroke. will these work? my block is bored .010 over, I have new auto/race tec pistons and they are set up for the stock 6.098 stroke, and the next size up stroke they have listed is 6.125. the 6.100 should work right? im also running trick flow gen-x top end kit with 225cc heads with their supplied parts. I just wanna make sure these rods will work cause I want to retain the free floating of the wrist pins and not modify the stock rods to do so.
Old Jan 7, 2014 | 01:15 AM
sick cc's Avatar
sick cc
night bump?
Old Jan 7, 2014 | 04:44 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Yes 6.100 is what you need
To LS2 rods and piston help!
