A/C problem at idling
Old Jan 26, 2014 | 07:08 PM
Mad*Max's Avatar
Mad*Max
Default A/C problem at idling
I have a problem with my car's A/C - when I am stopped at a light - it will sometimes start to blow warm air as though the compressor is shutting off.
The car runs fine otherwise and the air conditioning turns the car into a fridge when driving without stopping regardless of the outside temperature. The radiator fan comes on (even at idling) but I do notice the voltage is around 12.1 when stopped with the A/C on.
It is an 07 A6 with 55k miles. TIA
Old Jan 26, 2014 | 07:41 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'm no refridg guy, but sometimes that happens to ac when it's low on "freon". Reason is, it's compressing when running at above idle, but loses some of that compression-ability when the rpms drop.
Today, they (meaning service places) don't just "top up" or fill a little. They almost always "drain, clean and add" which, of course, is an added cost. But it keeps the environment clean, checks for leaks, recycles used freon, and eventually "tops up" your system.
The question is to find where it can be done for the least amount, but competently. Good luck. That's my best guess.
Old Jan 26, 2014 | 08:46 PM
truckplay's Avatar
truckplay
it sounds like a voltage problem. you should check the alternator output and battery condition first. the computer may be shutting the ac off due to low voltage.
Old Jan 26, 2014 | 09:43 PM
VET4LES's Avatar
VET4LES
If your a little bit mechanically inclined you can buy a gauge and can of R134 and top it off yourself. Read the can and ware goggles. I've done it and it's not a big deal if it's a little low. The gauge will tell you.
Old Jan 27, 2014 | 07:34 PM
Mad*Max's Avatar
Mad*Max
thanks for the responses - I should add that this has been going on for the last 3-4 years and I have had a new battery during this period (on a preventive basis)
Old Jan 27, 2014 | 07:48 PM
saplumr's Avatar
saplumr
If the situation hasn't worsened in the last several years that reduces the chance for refrigerant leak being the issue. I'd make sure the fans are running properly. Intermittent high condenser temps will cause what you describe as will a low pressure switch but as I said that doesn't seem logical.
Old Jan 27, 2014 | 08:06 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
The 05's were overfilled from the factory which would cause this symptom, particularly on hot days at idle...the system would pressurize too much and kick off the compressor under high pressure. There is a TSB on it, and the fix is to remove the freon and add less. Sounds counterintuitive but it's true.
Or just let some out if you are less environmentally friendly.
You can scan the ac pressure PID if you have HP Tuners and see if perhaps your car is overfilled.
Old Jan 27, 2014 | 10:01 PM
majorpayne317641's Avatar
majorpayne317641
I have had similar issues of this type on the c6 and other vehicles. You may be over or under charged. There is no real way of knowing the volume of gas inside your system, only the pressures on the high and low side. There may be an obstruction at the orifice tube, a bad compressor, or a very hot day and heat soak (although that would only be after a quick stop start like turning off the engine to refuel). The best way to begin to try to solve it is drain the system, replace the orifice tube and accumulator while your already there, then vacuum the system for 1 to 2 hours, then refill to the proper oz spec. The service manual or a search on the forum will give you capacities for freon and oil. A set of gauges and a vacuum pump can be had for about 180 these days.
Old Jan 28, 2014 | 04:38 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
informative posts from joeg and major above.
Old Jan 28, 2014 | 02:16 PM
psxer989's Avatar
psxer989
I had the exact same problem in my 06. I bought the DIY recharge kit from Autozone because thought I was low. When I hooked up the gauge it showed I was high. It wasn't by very much. I let some out and it has been fine ever since. As was stated above, if there too much "freon" it causes too much pressure.
Old Jan 28, 2014 | 08:03 PM
Mad*Max's Avatar
Mad*Max
Did yours start doing this after a few years? What I am trying to figure out is as to whether the level of Freon can increase over time (mine used to work normal for the first few years).
Old Jan 28, 2014 | 08:21 PM
saplumr's Avatar
saplumr
That is impossible.
Old Jan 28, 2014 | 08:34 PM
Mad*Max's Avatar
Mad*Max
Originally Posted by saplumr
That is impossible.
I didn't think so, nor did I think that too much Freon would cause the A/C to blow warm air
Old Jan 28, 2014 | 08:37 PM
saplumr's Avatar
saplumr
Oh, that's definitely a fact. My 05 was fine for the first 6 months when new and then had the blower installed. Found that flaw immdeiately and the dealer adjusted as tsb called for. I doubt that happened after the 05 but who knows, mistakes can happen.
Old Jan 29, 2014 | 12:14 AM
psxer989's Avatar
psxer989
I bought my c6 used so anything could have been done to the freon level. Just saying high pressure will cause the issue and it's pretty easy to check.
Old Jan 29, 2014 | 10:03 PM
Mad*Max's Avatar
Mad*Max
thanks all - I will have it looked at when it warms up a bit
Old Jan 30, 2014 | 11:13 AM
gbrtng's Avatar
gbrtng
I agree - 12.1 volts is too low, even at idle. You should see about 13.5 to 13.8 at idle - does the voltage increase above idle? If so, one of the diodes in the alternator's diode trio is probably shot. See if the AC compressor kicks in when the voltage is up in the normal range.
Glenn
To A/C problem at idling
Old Jan 30, 2014 | 05:35 PM
Mad*Max's Avatar
Mad*Max
Glenn
This condition has been present for over 3 years and yes the voltage is north of 14v when running on the highway - I am guessing that if it was the alternator then it would have conked out by now? The battery has been replaced after these symptoms have started and no change.
Old Jan 30, 2014 | 09:30 PM
cclive's Avatar
cclive
Too much freon causes a high pressure condition, tripping the high pressure switch and shutting the compressor down...hence the warm air. The battery is not really involved in the voltage of the system when the engine is running..this is controlled by the alternator. Check the system voltage on the DIC when the warm air problem happens at idle and make sure that is is at least in the high 12's. If the voltage is OK, then it is a freon level problem...either high or low.
Old Jan 31, 2014 | 12:30 AM
rowdymax's Avatar
rowdymax
Totally agree..Overfill can cause the same problem and more likely at just idle...Release some and see if it continues...If not, you can always add a little more later...Didn't know it was that hot in canada during the winter???
