Clutch MC quick disconnect leaking
Old Jan 27, 2014 | 06:55 PM
majorpayne317641's Avatar
majorpayne317641
Default Clutch MC quick disconnect leaking
I noticed some brake fluid on my frame and also kept having a slow low brake fluid problem in my clutch MC reservoir. I tracked it down to the quick disconnect fitting. Does anyone know the type of o ring used there? I have been considering a tick MC upgrade since I do have issues in first and reverse at times. Anyone had the same problem?
Item number 16 on this parts diagram:
http://parts.nalleygmc.com/showAssem...ssembly=403836
Old Jan 28, 2014 | 05:25 PM
majorpayne317641
Bump
I managed to take the black quick connect fitting off both ends. Now I have two male ends that are clip fittings with o rings. Anyone know of a way to convert these to AN fittings?
