09 vert "top not secure message"
Old Feb 4, 2014 | 02:49 PM
rrrrron's Avatar
rrrrron
1st Gear
Default 09 vert "top not secure message"
Top not secure message on when top is in up position.I believe it to be the switch located in drivers side windshield header.Can anyone give me some disassembly instructions for getting the header apart and the switch out?? Thanks Ron
Old Feb 4, 2014 | 03:19 PM
RicK T's Avatar
RicK T
Haven't had to do it but apparently it isn't a big deal. While the switch may be bad, it's also possible it's just out of adjustment.
Tips in these threads say to just pop the plastic cover off and bend the engagement contact a little, but be cautious as it seems to be a little flimsy:
http://forums.corvetteforum.com/c6-c...e-warning.html
http://forums.corvetteforum.com/c6-c...e-message.html
http://forums.corvetteforum.com/c6-c...ot-secure.html
Old Feb 18, 2014 | 03:53 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
And expensive...
Old Feb 18, 2014 | 07:36 PM
cclive's Avatar
cclive
Rick is right...most likely the switch is out of alignment. It may also need a spritz of electrical contact cleaner. You can do the spray without removing it. Push on the lever with a small screwdriver and see if you can hear the click of the switch making contact.
To 09 vert "top not secure message"
