2013 GS X-pipe
Old Mar 18, 2014 | 12:34 PM
gfacter's Avatar
gfacter
Default 2013 GS X-pipe
Hello,
I just bought a 2013 GS over the weekend.
I would like to install a Elite tunnel plate and while I am at it replace the 2013 X-pipe that has mini cats on it with one that does not.
Are all the LS3 specific x-pipes (Corsa, Borla, GM) the same dimensions? They should just bolt up right?
The tunnel plate really worked well on my C5 Z06, I think its a must have even if the c6 chassis is stiffer.
Thanks,
George
Old Mar 18, 2014 | 02:01 PM
Flying24's Avatar
Flying24
I don't think it's that easy, I have a 2012 Z06 I change out the complete system headers to exhaust. Read the article in the link
http://www.corvettenewsblog.com/tag/...vette-exhaust/
Old Mar 18, 2014 | 02:04 PM
Flying24's Avatar
Flying24
The article was written in 2012 but I'm sure it carried over to the 2013 model years as well.
Old Mar 18, 2014 | 02:29 PM
Flying24's Avatar
Flying24
I actually change my entire system, because of the additional CATS. I had a earlier thread which I'll post the link here. Where I was wiping white residue from the claps. Once pulled apart the pipe going to the aft CAT had white residue in the bottom of the pipe. Then further back where it goes over the axle white residue again. My thought CATS do deteriorate over time. But with a addition one holding them up from exiting. Plus I only had a few thousands mile.
http://forums.corvetteforum.com/c6-z...onnection.html
Old Mar 18, 2014 | 02:38 PM
gfacter's Avatar
gfacter
Its never easy. Thanks for the info
Old Mar 23, 2014 | 03:31 PM
PassNU's Avatar
PassNU
I'm guessing you have the same mid "cats" as on my 2012 GS. The front cats are on the end of the headers, yes? - Anyway, I cut the mid cats and had a short piece of straight pipe welded in. Added a bit to the volume of my exhaust, no complaints. Because they don't mess w/ sensor readings you don't have to worry about any CEL's or reading issues.
Old Mar 24, 2014 | 03:03 PM
JCtx's Avatar
JCtx
Originally Posted by gfacter
Its never easy.
In this case, IT IS . I replaced the catted X-pipe on my '12 GS with an OEM '11 GS one, and it bolted perfectly. Total cost was $110 delivered, sold by a forum vendor named 'JJFormato' (Jeremy Formato). I wanted an OEM job, so did this rather than a hack job any DMV with emissions testing would fail due to obvious modification. Your call. Pic attached so you know what you're looking at . Good luck, and hope this helps.
Old Mar 24, 2014 | 06:56 PM
gfacter's Avatar
gfacter
Looks the same size to me just no cats. Thanks
Old Apr 5, 2014 | 08:44 PM
gfacter's Avatar
gfacter
Update,
I bought a new Borla (60533) X-pipe "off road use only" it bolted right up, I ditched the extra cats and weight. A nicer burble on decal and maybe a tad louder with full throttle (NPP). Hard to say if those cats are sapping any power.
Anyway, did the x-pipe and tunnel plate in less then 2 hours.
Lost some weight and stiffened up the chassis a bit.
To 2013 GS X-pipe
