2012 GS - Does anyone have a good tutorial on brake pad replacement? I just started tracking the car & want to learn how to change the brake pads. Got the Hawk one piece pads. The stock pads stopped great but are to dusty.
Since you bought the one piece pads you will have to remove the calipers. If you have ever changed brake pads on any other vehicle you can change the pads on your GS.
No need for a manual... as mentioned above, if you have ever changed pads on any other vehicle... then you already know how to do it.
The only difference I noticed was the Clip in Spring tab thing... it just goes in to keep the pads from rattling... It was a little tricky on the first set, it took me about 1 minute to figure out... after that it was all down hill and I can now change all 4 pads in less than 20 minutes.
This is my first time ever replacing pads.
Not sure about the sequence / lubrication / tork settings / etc.
That is why i was looking for a picture tutorial
