Radiator AC Condensor Tip
Old Apr 5, 2014 | 11:54 AM
FIRST81C3's Avatar
FIRST81C3
Cruising
Default Radiator AC Condensor Tip
I got this new to me 05 and have been going thru it . I was looking up into the area under the front that goes to the rad and ac , when I noticed debris up there so I got my shop vac and carefully sucked everything out . My results were lower coolant temp and better ac Check yours out
Old Apr 5, 2014 | 12:47 PM
cclive's Avatar
cclive
Good call by you!
Old Apr 5, 2014 | 01:20 PM
victorf's Avatar
victorf
After cleaned up.
Use this stainless weave and edge trim:
To make this also helps:
To Radiator AC Condensor Tip
