Tick Performance Adjustable Clutch Master Cylinder
Old Apr 9, 2014 | 07:02 PM
rmm82's Avatar
rmm82
Default Tick Performance Adjustable Clutch Master Cylinder
This question is for those that own a 2009-2013 vehicle and installed a Tick performance clutch master cylinder.
The instructions at Tick's web site indicates that a "Clutch Pedal Position Relearn" procedure is necessary for 2009-13 years. However, my Chevrolet dealership performed the procedure, but says the system still detects the clutch out of position (or depressed).
Has anyone had this procedure done with successful results? Has anyone encountered the same problem as me?
Thanks in advance for your comments.
By the way, I love the Tick product, the clutch finally feels and behaves like it should.
Old Apr 9, 2014 | 07:30 PM
RicK T's Avatar
RicK T
Not exactly an answer but info and maybe someone to contact for more info if you don't get it here (see post 3):
http://forums.corvetteforum.com/c6-z...n-a-09-c6.html
Old Apr 10, 2014 | 01:02 PM
rmm82's Avatar
rmm82
Default Update
Just an update. If your dealership does the clutch pedal relearn procedure and things like cruise control still don't work, try disconnecting the battery for 10 minutes. When you reconnect it, the computer reboots. And guess what - now things like cruise control work. Amazing!
To Tick Performance Adjustable Clutch Master Cylinder
