Clutch help
As for the flywheel, all depends on the condition of it once it pulled (it get pulled to replace the crank seal behind it on a clutch replacement). You can get a new LUK flywheel for $60 if it's toasted (LUK Part # LFW191), or if the flywheel just needs to be cleaned up, could be even cheaper.
As for bearing noise, I would first start off by making sure that the clutch fluid is clean and free of any contaminants. What you think is something going south, may in fact just be that the fluid is contaminated, and the slave cylinder not fully releasing the clutch instead.
As for changing the clutch fluid, there is a ranger method with a lot of peddle pumping, or you could have the system power bleed instead.
Also, if the problem is dust on the shaft that is binding up the throw out bearing to cause the noise, the built up clutch dust in the bell housing can be cleaned by just pulling the starter to clean out all the dust out that way (through the starter channel and the air vent passages).
Either way, your in the $2K range to have a clutch replaced (with all the other parts that you change out at the same time once you get that deep), so before you go that far, see if changing the clutch fluid, and even blowing out the dust in the bell housing solves the problem first (just time on your part to do these).
As for the flywheel, all depends on the condition of it once it pulled (it get pulled to replace the crank seal behind it on a clutch replacement). You can get a new luk flywheel for $60 if it's toasted (luk part # lfw191), or if the flywheel just needs to be cleaned up, could be even cheaper.
As for bearing noise, i would first start off by making sure that the clutch fluid is clean and free of any contaminants. What you think is something going south, may in fact just be that the fluid is contaminated, and the slave cylinder not fully releasing the clutch instead.
Either way, your in the $2k range to have a clutch replaced (with all the other parts that you change out at the same time once you get that deep), so before you go that far, see if changing the clutch fluid, and even blowing out the dust in the bell housing solves the problem first (just time on your part to do these).
