2008 Bolt On Dyno #'s
Old Apr 14, 2014 | 12:48 PM
nspendleton's Avatar
nspendleton
Default 2008 Bolt On Dyno #'s
I recently dyno'd my 08 to see where I was sitting and figured I would share. Ended up with 416rwhp and 410rwtq!
My car: 2008 Base 6MT with approximately 55k miles
Mods:
Hurricane Intake
TSP 1 7/8" long-tube headers
TSP X-pipe with 3" Magnaflow cats
Corsa Xtreme axle back exhaust
Custom street tune by Charles Hill @ LsXperts
Next Up:
LsXperts Shake and Bake custom grind cam!
Old Apr 14, 2014 | 04:28 PM
Pitufina's Avatar
Pitufina
Seems strong. Cam will wake it up for sure.
Old Apr 14, 2014 | 07:09 PM
Boomer111's Avatar
Boomer111
With basically same mods I had 422/422.
I had 1 3/4 in long tubes catted and the Vararam intake with Corsa Sports.
Dynojet SAE
Old Apr 15, 2014 | 08:07 AM
nspendleton
Dynojet SAE
Dyno or street tuned? What was the temp of your run? It was right about 75F when I ran this. I previously hit right over 404/396 before the headers but that was this fall and it was like 45F.
Old Apr 16, 2014 | 08:22 AM
Boomer111's Avatar
Boomer111
This was in February so it was a cool day. Probably mid 40's. Dyno tune with street adjustments.
The car was first tuned at 800 miles and showed 400/400, stock with tune.
375/381 before tune at 800 miles.
The later two runs where in late Winter too so again mid 40's temps.
Old Apr 16, 2014 | 11:56 AM
Gabbiani's Avatar
Gabbiani
Sounds about right. Not sure what dyno you were on.
Dynojet numbers for me were 426/423 SAE5 with the following:
Calloway honker intake
Kooks 1 7/8" Long Tubes with Cats
My tune
Stock everything else
Old Apr 17, 2014 | 01:47 PM
nspendleton
I was on a DynoJet 248. I just put the parts deposit down on a cam and hope to have it installed this month, so more power is on the way!
Old Apr 18, 2014 | 05:44 PM
24/Eray's Avatar
24/Eray
comparing one car to another for power on a different dynos is futile. your before and afters are all that matters.. Truthfully, all that matters is the butto dyno and track times unless you just want to "see" big numbers and brag.
My friend's AWD Mustang dyno is a dream killer lol.. people come in there, run their cars and can't believe they're not seeing these inaccurate static roller dyno numbers.. As they say, the truth really does hurt. But i'd rather have the truth than have smoke blown up my ***.
What did your car put down on that dyno stock?
Old Apr 19, 2014 | 01:54 AM
collinms's Avatar
collinms
I have an 08 m6 and put out 440hp 445tq with the following mods:
Super bee mf103 cai
LG super pro 1 3/4 w/ hfc
Billy boat prt
Vengeance tune
Before the headers I was 415hp 412tq
Old Apr 20, 2014 | 10:10 AM
Boomer111's Avatar
Boomer111
Super bee mf103 cai
Billy boat prt
Vengeance tune
Very high numbers for listed mods..
It is Z06 territory.
Usually numbers are between say 415-428 for rwhp for listed mods.
Old Apr 20, 2014 | 01:00 PM
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
DynoJets are inertia dynos, and have been around for years, much longer than any type of load cell dyno. Inertia dyno's work on the principle of the acceleration of a known mass over time. Their rollers are the known mass. Weighing in at over 2500lbs or so. Your car gets strapped down to the machine, and the dyno collects it's data. It is able to calculate horsepower by measuring the acceleration in rpm of the rollers in regards to RPM. This is why gearing can affect the dyno results, more on that in a bit. Now that the dyno has recorded the horsepower curve, it can take the integral of that curve and get the torque curve. Since the dyno’s power calculations are based on the acceleration of mass over time in regards to RPM, gearing is very important. Since a vehicle with a lower gear ratio can accelerate the mass to a higher speed using less engine RPM, it will show a higher horsepower number than a car with a higher gear ratio. If a car is able to accelerate the dyno’s rollers from 200rpm (roller) to 300rpm (roller)in 1500rpm (engine), then the dyno is going to record more power than a car that did that in 2000rpm (engine).
Now we go to Mustang dyno’s and other loaded dyno’s. Our Mustang MD-1100SE dyno’s rollers weigh 2560lbs. That is the actual mass of the rollers, much like the DynoJet. That’s about where all the similarities end. When we get a car on our dyno, we enter two constants for the dyno’s algorithms. One being the vehicle weight, the other being what’s called “Horsepower At 50mph”. This is a number that represents how much horsepower it takes for the vehicle to push the air to maintain 50mph. This is used as the aerodynamic force. Mustang dyno’s are also equipped with a eddy currant load cell. Think of a magnetic brake from a freight train. This magnetic brake can apply enough resistance to stall a big rig. Off one side of the eddy currant load cell, there is a cantilever with a 5volt reference load sensor (strain gage). As the rollers are spinning this load sensor is measuring the actual torque being applied. So as the rollers spin, the load sensor is measuring the force being applied, sending that information to the dyno computer, taking into account the two constants entered earlier, computing the amount of resistance needed to be applied to the rollers to load the car so that the force of the rollers resistance is as close to the force the car sees on the street. The dyno is then able to calculate the total force being applied to the rollers in torque, and then taking the derivative of that torque curve to arrive at the horsepower curve. Since torque is an actual force of nature, like gravity and electricity, it can be directly measured. Horsepower is an idea that was thought up by man, and cannot be directly measured, only calculated.
I like to state it like this. . . I start by asking how much your car weighs, lets say 3500lbs. Now you take your car and you make a make a WOT rip in your tallest non overdrive gear, how much mass is your engine working against? 3500lbs right? Now you strap your car on a DynoJet and you make a WOT in the same gear, how much mass is your engine working against? 2500lbs right? Now you strap your car on a Mustang dyno, how much mass is your engine working against? 2500lbs. Plus the resistance being applied by the eddy current generator. We’ve seen anywhere for 470lbs of resistance to over 700lbs of resistance as measured in PAU force in the data logs. So which one is more accurate? Well they their both accurate. If a DynoJet dyno says you made 460rwhp, then you made 460rwhp. If a Mustang dyno says you made 460rwhp, you also made 460rwhp. Now which one of those numbers best represents what your car is doing when its on the street. That’s a different question.
The most important thing to remember is that a dyno is a testing tool. If the numbers keep increasing, then you’re doing the right thing. We try to look over at NET gain, instead of Peak HP numbers. A 30rwhp increase is a 30rwhp increase regardless of what dyno it is on.
Now I can address how to calculate the difference between one type of dyno and another. Simply put, you can’t. Because Mustang dyno’s have so many more variables, it’s not a simple percentage difference. We’ve had cars that made 422rwhp on our Dyno, two days later make 458rwhp on a DynoJet the next day. We’ve also had cars that made 550rwhp on our dyno, make 650+rwhp on a DynoJet a few days later at another shops Dyno Day. For instance, my 2002 Z28 with a forged internal LS6 Heads/Cam/Intake, makes 460rwhp on our dyno. I thought that was a little low, since I’ve had cam only LS6 Z06 vettes make 450rwhp. So I overlaid the dyno graphs. Guess what, the PAU force for my car was almost 200lbs more than the C5Z06 that made 450rwhp with cam only. So I entered the weight and horsepower at 50 number for a C5Z06 and did another horsepower rip with my car. The only reason I did that was to compare Apples to Apples. This time my car made 490rwhp, no other changes. Now I don’t go around saying my car made 490rwhp, I say what it actually did with the correct information entered into the computer. It made 460rwhp. Now if I ever get a chance to take it on a DynoJet (which I plan to in the spring), I have no doubts it’ll be over 500rwhp. I know this based on airflow and fuel consumption on the data logs.
But since we’re asked this question constantly we're fairly conservative, and hence tell our customers that the difference is closer to 6-7%, but as you make more power, and the more your car weighs, the difference increases as well. You must remember, Dyno's regardless of the type are tuning tools, and are in no means meant to tell people how fast their car is. Now which one is more "real world" is a totally different question. I like to explain it like this..... If you drive your car in a situation in which you have no mass and you're in a vacuum, so basically if you do intergalactic racing in space, use a DynoJet. If your car sees gravity, and has an aerodynamic coefficient, and you race on a planet called Earth, then use a Mustang Dyno.
To 2008 Bolt On Dyno #'s
