Vette light bulbs
Old Apr 14, 2014 | 11:34 PM
b_mouzakis's Avatar
b_mouzakis
Default Vette light bulbs
I've almost had my Vette for a year. Since its purchase I have replaced all the light bulbs i.e. Head lamps front blinkers and rear taillight/blinker bulbs. Replacing them is relatively easy. Just wondering why they keep blowing out. My own conclusion is the ride is rather stiff and this jarring motion is causing the filament to fail.
Has anybody else experienced similar or am I the lucky one?
Bill
Old Apr 15, 2014 | 12:23 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Your are apparently the lucky one. Mine is an 08 and I don't think I've replaced a single bulb yet and I am approaching 100,000 miles.
IF all the bulbs are affected I'd take a close look at the grounds. There are about 7 or 8 located all around the car. Start with the 2 closest to the BCM and the drivers side.
Old Apr 15, 2014 | 01:51 AM
Zoxxo's Avatar
Zoxxo
All original bulbs on my 2007 w 80k+ miles. What's a bit surprising is that I still have all the original bulbs operating just fine in my 1992 Toyota MR2T (purchased new) w over 200k miles (!!)
Maybe you have an issue?
Z//
Old Apr 21, 2014 | 11:32 PM
b_mouzakis's Avatar
b_mouzakis
Thanks guys for your help I think I will be visiting the dealer soon
Old Apr 22, 2014 | 02:35 PM
gbrtng's Avatar
gbrtng
If the alternator voltage is higher than normal bulb life will decrease. A high voltage transient may have caused the problem too, but only to the ones that are normally lit.
To Vette light bulbs
