What to do next power wise??????
Old Apr 21, 2014 | 01:21 PM
Justasheet's Avatar
Justasheet
Originally Posted by C U IN REARVEIW
I have never experienced wheel hop since the coilovers went on.....and it tends to break loose alot....lol
Most of the destructive wheel hop occurs at the drag strip with drag radials and a prepped track. I don't get much traction on the street anymore. C U IN REARVIEW, it's good to see another firefighter in an 05 such as myself.
Jeff
Old Apr 21, 2014 | 01:49 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Jeff
For sure, love my 05.....what is your current set up (justasheet)? Hp/tq? F/I or n/a?
Old Apr 21, 2014 | 02:06 PM
Justasheet's Avatar
Justasheet
PM sent.
Old Apr 21, 2014 | 02:23 PM
morris05vette's Avatar
morris05vette
I havent had a wheel hop issue yet and i do drive it like i stole it, maybe itll start once more power goes in
Old Apr 21, 2014 | 06:21 PM
Justasheet's Avatar
Justasheet
I hope it doesn't. The diff usually takes the transmission out with it when it goes. Some people never have a problem, some do. I like to go to the track so I considered it preventative maintenance.
The best single mod for you is probably a set of 4:10 gears. It won't add any HP but you will think it did and you can fix the diff while you're in there too. Same labor (almost).
Jeff
Old Apr 21, 2014 | 08:35 PM
C U IN REARVEIW
A ported fast 102, custom cam and a good set of heads will get you to 500whp
Old Apr 22, 2014 | 08:17 AM
Justasheet's Avatar
Justasheet
...and possibly a broken diff. I may just be paranoid but I started my build from the weakest link and moved forward with my end goal in mind. Lots of good info and opinions shared on this forum. Good luck to the OP with his build.
Jeff
Old Apr 22, 2014 | 09:28 AM
morris05vette
I had bought an anti wheel hop kit (bigger axles) for my GTO and they worked awesome especially at the track.......is there anything like that for the vette??
No ones answered this question yet......
Old Apr 22, 2014 | 12:04 PM
Justasheet's Avatar
Justasheet
I have no knowledge of such a thing. Stronger axels I have but how they would prevent wheel hop is beyond me. Sorry.
If nobody responds to your question, it is probably because they don't know either. Maybe you could look into this and let us know?
Jeff
Old Apr 22, 2014 | 12:24 PM
morris05vette
I have no knowledge of such a thing. Stronger axels I have but how thet would prevent wheel hop is beyond me. Sorry.
Jeff
Well if its anything like my GTO was, they would be replacing the stock axles with stronger ones. The GTO kit was a really fat axle on the left side with a thinner axle on the right. Apparantly the wheel hop starts from the left side and makes its way over to the right. Very strong kit from Gforce 1320 was about $600. Ive found a kit for the corvette with stronger axles and pricing is $1300-$2000+ but does anybody have anything like this??????
Old Apr 22, 2014 | 04:09 PM
Justasheet's Avatar
Justasheet
I'm not sure. I've heard of replacing our 05 axles with C5 Z06 axles which are supposed to be stronger but that was to prevent the axle from breaking and not as a cure for wheel hop. Maybe it helps? I have no knowledge on this. Someone else needs to chime in. As I mentioned earlier to you, send Stanger383 a PM. He can answer this for you.
Jeff
Old Apr 22, 2014 | 04:19 PM
timd38's Avatar
timd38
Jeff
The reason one is bigger than the other is to stop harmonics that will help reduce wheel hop. Gordon Rojewski has the patent on it.
Old Apr 22, 2014 | 04:25 PM
  #33
Jers06C6's Avatar
Jers06C6
I had a 2001 Camaro SS that had some wheels hop. Swapped out the rear shocks for adjustable drag shocks and wheel hope was nonexistent. Not sure if its that "easy" on a vette with independent rear.
Old Apr 22, 2014 | 04:26 PM
  #34
dennis50nj's Avatar
dennis50nj
in 05 the drivers side axle was really small in diameter, I broke one at the spindle the dealer replaced with a much fatter one, but was still the same diameter were it broke in the spindle damaging the spindle and bearing, non run flats help prevent wheel hop, also bigger side wall tires like 17" 16" 15" and better shocks, dual adjustable. just very slight wheel hop breaks the case, like a little dew in the air, tap the throttle with run flats that quick kaboom, no wheel hop it will live a long time
Old Apr 22, 2014 | 04:48 PM
  #35
Justasheet's Avatar
Justasheet
Sorry I didn't throw your name out there too as a resident expert as well as Norm's. I think he's too busy with the new ride.
Thanks for weighing in Dennis.
Jeff
Old Apr 22, 2014 | 04:59 PM
  #36
dennis50nj's Avatar
dennis50nj
Jeff
no expert Jeff just lucky
