Slave quick connect
Old Apr 21, 2014 | 09:02 PM
onelesshat's Avatar
onelesshat
Cruising
Default Slave quick connect
I am at the tail end of a clutch/transmission swap. All that is left is to hook up the quick connect fitting from slave to master/reservoir. I have been fighting this for hours. Can some one give me a little guidance. I have my new tick bleeder wide open.
I can see that the slave end has a plastic t in the bottom of it. Does it have to be clocked a certain way, or is it just about brut strength.
anyhow Id love a new strategy to try.
Old Apr 22, 2014 | 05:53 PM
3X2's Avatar
3X2
I usually remove the spalsh shied, unbolt the brake master cylinder from the booster and move it out of the way. Somewhat start the clip in the retainer. I then reach through the opening created from removing the splash shield with my right hand holding the master cyliner line and using my left hand reach around where the brake master cylinder was and push the two pieces together then push the retaing clip into postition.
Old Apr 22, 2014 | 09:19 PM
Devilish34's Avatar
Devilish34
I had the same problem.. After fighting it I found out the quick connect on the new slave was defective.. Swapped the old one on and it went right together... Where did you buy the slave from?
Old Apr 23, 2014 | 08:18 AM
ColtaBilly's Avatar
ColtaBilly
That is a beast to reconnect. I have done it twice and each time it took two people. One person in wheel well(remove access panel) and the other on engine side. My son and I pushed like hell to get a good seal. Relieving the pressure in the system will make it a little easier. Just depress the tab on the slave and master ends Good luck
To Slave quick connect
