c6 headlight issue
Old May 2, 2014 | 04:46 PM
vetteboy06's Avatar
vetteboy06
3rd Gear
Default c6 headlight issue
Im having the same issue as many of you are having with my headlights Its looks like the fuse box should be easy to replace, My question is would a 06 engine fuse box from a 2006 z06 work in a z51 coupe? The label on the cover has a number of 21996325 the inside top lid has a number of 15497636-01 which is the part number thanks
Old May 2, 2014 | 08:16 PM
cclive's Avatar
cclive
Why not just fix the ten cent wire...it won't really be more work than replacing the entire fuse box...and the replacement may have the same issue with that one wire unless the previous owner of that box replaced the wire...
Old May 4, 2014 | 12:10 AM
4SUMERZ's Avatar
4SUMERZ
The fix of the broken wire under the fuse box is pretty easy, and since you have to remove anyway to replace with a used with potentially, or new, with still potential with the same issue down the road, do it yourself with a permanent fix for $5.00 and about 2 hours of your time.
I have made a PDF (with pics) of the process made from the original OP and other inputs.
If you want a copy of it, PM me your e-mail address.
To c6 headlight issue
