torque converter debate
Old May 13, 2014 | 05:13 PM
dicky's Avatar
dicky
Originally Posted by JBrunoJSBC6
Wow! So upgrading to a 3600 and swapping rear gears from 2.73 to 3.42's will net me into the high 10s/low 11s! That's insane! When you say all bolt ons, what are you considering other than headers/exhaust/CAI?
It's possible, there are 3 LS2's and a few ls3's into the 10's with just bolt ons, go to the fast list to see all. Of coarse when I ran those 10's I had skinnies on the front, they help me gain .15 to .2. Some have done it without the rear gear change, that mod only seems to gain about a tenth in the 1/4. I think the gears make the car feel better with the converter.
My mods are in my profile, the more weight you can cut the better.
Old May 13, 2014 | 05:39 PM
smaynor's Avatar
smaynor
My best repeatable 60' is 1.47. Can consistently do low 1.5x anytime I can hook. Car has 2.56 gears.
Mods are A&A Supercharger, Yank PAS3400, Headers, Vengeance Racing tune, MT 275/40-17 rears, 17 x 4.5 front skinnies, HP Tuners to work on the trans tune.
Car makes 551 rwhp and 506 rwtq.
My launch 'technique' is a little odd, but by watching my videos of my passes, and by looking at my data logs, here's what it appears I do.
I hold as close to 2000 RPM as possible when staging. Then I apparently 'roll into' the converter a little harder right before I release the brake. My logs say I leave right around 2500.
I would make the change to a 3.42 diff if I thought it would make a big difference in ET. I know it probably would, but I'm pretty happy right now. I don't really want to spend the $$$ for another .1 or so.
Stacey
Old May 13, 2014 | 07:16 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Has anyone heard or have the 3800 yank?
Old May 13, 2014 | 09:05 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
Anyone got 60' times? Last mods too please. I'm running 1.90 with headers, cai, stock stall and DR.
1.32-60 stock ls2 bottom with H/C Yank SS4000
1.42 Stock Z06 SS4000
1.22(yes 1.22) H/C Z06 Yank SS4000
Old May 13, 2014 | 09:38 PM
BSPC608's Avatar
BSPC608
1.43 -60 ft stock ls3 bottom with H/C Yank 4000SS 12lbs weight reduction switching stock fronts with CCW front runners 6lbs wt savings per wheel. Other than those wheels everything is from the factory except for the added roll bar.
Will swap wheels and auto cross this Friday at the Classic at Texas Motor Speedway.
Road Course is Sunday. Got to love what these cars can do.
Old May 14, 2014 | 12:07 AM
HOXXOH's Avatar
HOXXOH
Yank 4000 here in my '08 bolton and 1.4x 60' times. Previously had a Yank 3600 and mid-high 1.5's and previous to that had a Yank 3200 with 1.7's. Best ever with the stock converter was 1.85.
I added/changed some of the boltons during that time also, but this gives a fair comparison of stall speeds and launch abilities.
Old May 14, 2014 | 12:22 AM
dennis50nj's Avatar
dennis50nj
yes I have a yank PA3800 leaving soft 2000 rpm and roll back peddling 1.34 1.35 60 ft
Old May 14, 2014 | 12:32 AM
CI GS's Avatar
CI GS
Old May 14, 2014 | 01:08 AM
CI GS's Avatar
CI GS
Sounds like Yank is the overwhelming favourite and, with those kind of short times, I can understand why.
A few years ago, if someone told me that you could pull a 1.2-1.3 60' in a street car with drag radials, I would've thought they were nuts. These cars are truly amazing.
I'm thinking of doing the PAS 3800 myself, because I'm pretty sure I'm going to do a cam change and supercharge my car. My only worry is that I see that it is only rated for 650 HP, which looks like what yank rates all of its 9.5" converters at, whereas the 10.5s are rated at 1000hp.
Old May 14, 2014 | 10:39 AM
C7/Z06 Man's Avatar
C7/Z06 Man
How does it drive on the street. What made you decide to go with the PA3800 over the SS4000?
Old May 14, 2014 | 11:00 AM
JBrunoJSBC6's Avatar
JBrunoJSBC6
St. Jude Donor '14
Well its settled. Called up the local speed shop and ordered myself a Yank SS3600. Two week lead time on the build, but should be getting the converter and trans cooler done in early June.
Thanks everyone for the input, it greatly helped me decide which company to go with.
Old May 14, 2014 | 08:56 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
that converter is more suited to a power adder that he may run in the future.
Old May 14, 2014 | 10:17 PM
  #33
CI GS's Avatar
CI GS
Anybody know what the stall torque ratio is on the PAS converters? They're not on the STR list that Yank has posted on its website. They say that this series will "couple up quicker and multiply torque harder", but not sure what that means in terms of what they are comparing it to?
Old May 14, 2014 | 10:23 PM
  #34
CI GS's Avatar
CI GS
Also, does anyone know if Yank offers a multi plate clutch in their 9.5" units?
Old May 15, 2014 | 09:41 AM
  #35
dennis50nj's Avatar
dennis50nj
I had a 3800 vigilante so I wanted a 4200 4500, since Norm's 60 ft was so spectacular. Norm set me up with Dave at YANK direct. since I had around 500 rwhp and nitrous on the car they built the PA and it only comes in 3800, it lowered my 60 ft from 1.45 to 1.34 best on a light part throttle launch ft brake around 2000 rpm and roll easy into throttle to the floor 4 cars out, or I smoke the hoosiers. my best 60 ft with the vig was 1.41 with bolt/ons and weight reduction of a 150 more lbs the driver but once I went cam and then heads and cam the best with the weight back in the driver me 297 lbs was a 1.45 so the Yank cut 0.11 better. it drives on the street great, better then the vig as it couples quicker and goes into converter loc at a lower mph and stays locked until you give it a lot more gas pedal, were the vig if a fly landed on it would come out of overdrive. I'm really happy with it
Old May 15, 2014 | 10:18 AM
  #36
CI GS's Avatar
CI GS
Thanks, that's an excellent comparison of 3800 rpm stall converters for the Vig. vs. Yank debate right there.
So you're the guy responsible for this new line of Yanks, eh?
Sounds like the PAS3800 is a slightly tighter version of the SS4000 (maybe a stator tweak?) and the 3400 is a tweaked SS3600??
Thanks again. This is very helpful info.
Old May 15, 2014 | 10:45 AM
  #37
C7/Z06 Man's Avatar
C7/Z06 Man
Thanks for the in depth review. Being I drive the car it looks like the 3800 for me unless the Yank SS4000 would be "every bit" as good as the 3800 on the street which I think is unlikely. I "maybe" doing a C7 down the road so I will wait till I make my mind up before doing anything else to the C6.
Old May 15, 2014 | 09:19 PM
  #38
dennis50nj's Avatar
dennis50nj
I think Norms STANGER383 4000SS works the same, he is responsible for me getting the YANK, I have let a few Ford racers drive it and they said it was the best converter they ever drove, it locks so tight at 35-40 mph if you are driving easy you can actually give it a lot of gas and it stays locked and exhilarates like a stick in high gear but if you givr it quickly it unlocs and even downshifts, it keeps me in the 5000 rpm range as soon as you flash it you can even just hit the gas quickly let off and it flashes just like pushing in the clutch and pipping someone up
