When to change coolant
Old May 16, 2014 | 09:05 PM
Gering's Avatar
Gering
Tolero Apto Victum
Originally Posted by irok
have had people asking if I could weld up their oil filter because it had rusted thru or check noise in front end caused by brake rotor rusting,breaking in half and falling off car.dont recommend these maintenance schedule's either. coolant replacement=chump change
Old May 16, 2014 | 09:08 PM
Gering's Avatar
Gering
Tolero Apto Victum
Originally Posted by Purple92
I think most of us know that anti-freeze (be it Dex Cool or the earlier Green Ethylene Glycol version) has a lot of stuff in it other than the Ethylene Glycol that keeps the coolant from freezing. One of the other things is a corrosion inhibitor package. I'm not a chemist, but that corrosion inhibitor package does not last forever, and when it looses it's effectiveness, you will definitely see dissimilar metals in the cooling system corrode. Will your entre cooling system turn to a corroded mess one day after the five year service interval - of course not !!! But, it certainly seems like false economy to try to save $25 and a couple hours of your time by not buying two gallons of Dex Cool, and to have a head gasket or a radiator fail because the coolant failed to protect these components from corroding...
I've had the "pleasure" of working on a C4 that had eon's old coolant in it (this is prior to the "extended life coolants, and the Dex-Cool days). When I finally did a coolant drain - the stuff that came out of the block drains was dark brown... When the heads came off the engine a while later, there was a "green slime" in the cooling passages of the cylinder heads that was nearly impossible to get off (a 2,000 psi pressure washer didn't even make a dent in the stuff). Think that cooling system was operating anywhere near as efficiently as it should ???
Fundamentally - the fluids in our cars - be it Engine Oil, Coolant, Brake Fluid, Gear Oil etc. are cheap compared to the damage that can be done if they're overlooked for too long. Enough Said ???
Old May 29, 2014 | 10:02 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
where do you drain from radiator to get the max mount of coolant out? lower hose or is there a plug? should I flush with distilled water before refilling with coolant? 05 z51
Old May 29, 2014 | 03:30 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
There is a drain at the bottom of the radiator, passenger side IIRC. Gets about half of the coolant out, OCD people like me will refill with distilled and run the engine long/warm enough to get the thermostat open and mix the old and new, then drain again. Can even do it once more if you really want. Fill with 50-50 Dexcool/distilled water.
The filling instructions are in the Service Manual and are not complicated, but lots of people seem to have problems with air locks in the system when using some other methods, I'd get the right info.
GM says you can use clean tap water, and that seems to work ok. But I sent a sample of my factory coolant to a lab and they flagged it for excessive hardness and recommended always using distilled.
Old May 29, 2014 | 06:00 PM
C U IN REARVEIW
IM OCD AS WELL SO....DOUBLE FLUSH IT IS!! thanks
Old May 29, 2014 | 10:29 PM
RICH 28's Avatar
RICH 28
If you are draining it multiple times then it is safe to say there is no more Dexcool left in the system, just distilled water. So, in that case I would fill with straight Dexcool to half of the cooling system capacity. Then top off with just distilled water only. This way you should have the proper mix.
Old May 29, 2014 | 10:37 PM
Gearhead Jim
St. Jude Donor '13
A good point, I actually used 50/50 for my "flush" because I wasn't sure if we would get the second drain/refill done in time that day.
Old May 29, 2014 | 11:44 PM
Bill Dearborn's Avatar
Bill Dearborn
I change mine every 5 years. Currently my 03 Tahoe with 98K miles on it is on the third fill. My 08 Malibu is on its 2nd fill and the 08 Z06 is on its first fill since the engine was replaced two years ago due to a dropped valve head. Have been doing that since I purchased my 97 the first car I had with Dex in it. Every one I changed the coolant looked just like it did when it was first put in.
When I change the fluid I use regular drinking water just like the FSM recommends. No need to use distilled or deionized water. I drain the system, refill using the garden hose and drain again. I repeat until the drained fluid runs clear. Then I add half the capacity of Dex and top off with water. Has worked fine on 7 different cars.
Bill
Old May 30, 2014 | 10:01 AM
haljensen's Avatar
haljensen
The owners manual for my '08 states 5 years or 150,000 miles for coolant change. The label on the Prestone DexCool jug says the same thing, 5 years or 150,000 miles.
Old May 30, 2014 | 10:44 AM
C U IN REARVEIW
So what is the total amount of coolant in the system (z51 if it matters)? Im at the fire department and dont have my manual on hand....
Old May 30, 2014 | 04:16 PM
Red08's Avatar
Red08
If it was mine, I would change it
Old May 30, 2014 | 06:45 PM
haljensen's Avatar
haljensen
My '08 book says 12.5 quarts.
Old Jun 6, 2014 | 10:31 PM
  #33
C U IN REARVEIW
How do you get the sludge in the overflow tank clean
* residue on the sides*
* if there is brownish looking residue in the overflow tank....would it be in the engine as well? I flushed it three times...*
Old Jun 7, 2014 | 02:35 PM
  #34
C U IN REARVEIW
bump
Old Jun 8, 2014 | 01:57 PM
  #35
Cherokee Nation's Avatar
Cherokee Nation
Remove it,then bleach & water...
Old Jun 8, 2014 | 02:00 PM
  #36
Cherokee Nation
I want even drink tap water....
Old Jun 8, 2014 | 02:35 PM
  #37
Thomasmoto's Avatar
Thomasmoto
I'm OCD as well so our 2011 GS with 70,000 miles is getting it changed soon.
Old Jun 7, 2020 | 11:19 AM
  #38
Sixgun95's Avatar
Sixgun95
Deleted
