Codes after header install
Old May 18, 2014 | 07:49 AM
hammersavette's Avatar
hammersavette
Default Codes after header install
Fellow forum members, I installed a spanking brand new set of OBX headers and flowmaster exhaust on my 06 a6 corvette, no tune yet. After about 400 miles of driving, I got a check engine light. Now mind you, I did not expect a light from my front o2 sensors, but the rear ones is a different story altogether. I recieved sixteen different codes from both front and rear sensors. I dont want to tune it until I install my varaam intake, should be here in a few days. I did the rear o2 trick, using sparkplug extenders. I used the o2 wires within the harness for the front, had to cut open harness to get to wires, but it worked. If rear sensors throw codes? does that confuse the front ones? or do I just need a tune? I tell you one thing, this vette runs like a scared ape. I"m going to cut the check engine light out and drive it again. SOO much fun
Old May 18, 2014 | 09:21 AM
shawnaj7731's Avatar
shawnaj7731
Yes the codes are from the Rear o2 sensors if you list the codes it spitting out we can give you a better direction but you will continue to get the codes until the car gets tuned.
Old May 18, 2014 | 10:34 AM
hammersavette
Will I hurt anything if I keep driving it until I get my varaam and tune?
Old May 18, 2014 | 10:52 AM
shawnaj7731
nah you shouldnt but i would try to not to get on it.
To Codes after header install
