Blown Engine - Replacement Options
Old May 29, 2014 | 11:31 PM
schizcat's Avatar
schizcat
@Crowhater
So, did you build your engine around the cam or just give Pat the specs on the setup you already had and build a cam around the setup?
Old May 29, 2014 | 11:43 PM
Crowhater's Avatar
Crowhater
Originally Posted by schizcat
@Crowhater
Weight of cat
Gear ratio
Cylinder heads
Flow numbers
Combustion chamber CC
Valve springs
Compression ratio
Displacement
Stroke
Header size
Intake
Racker ratio
Push rod length
Lifters
Transmission
What rpm converter
Tire size
Etc, etc.
If you go to his web site you can contact him and he will email you the data sheets to fill out. The more info you supply the better results you will get. I love my results, it dialed in the engine perfect for my combo.
The guerragroup.com
Here is a video of my car.
