Dry sump
Old May 30, 2014 | 02:21 PM
meanjoe's Avatar
meanjoe
Default Dry sump
Looking for ideas on replacing the cheap looking plastic lines that come off the stock dry sump tank. something like the pic below but with keeping the stock tank.
Old May 31, 2014 | 11:52 AM
meanjoe's Avatar
meanjoe
I guess nobody has ever replaced these??
Old Jun 2, 2014 | 12:10 AM
Quijeeboe's Avatar
Quijeeboe
If the stock parts have not failed I would strongly suggest leaving well enough alone.
If you currently have a warranty it will almost certainly void it and changing the lines will not be of any performance benefit.
Old Jun 2, 2014 | 01:33 PM
96GS#007's Avatar
96GS#007
They just carry vapors. If you're going to change them either you need to figure out how to use the stock connectors or you're going to have to modify tank side of the connectors for an AN style fitting or a barb style fitting. Seems like a lot of work for non-value added bling. Then again....your car
Old Jun 2, 2014 | 01:41 PM
timd38's Avatar
timd38
These guys can help you.
http://www.xrp.com/
Old Jun 3, 2014 | 05:24 AM
rmarks's Avatar
rmarks
Wow, that looks beautiful.
www.summitracing.com - AeroQuip
Go to a local hot rod shop and see what they stock. I used to work on race car plumbing
and you have to be careful with what fits what, etc.
Old Jun 5, 2014 | 01:27 PM
rabrooks's Avatar
rabrooks
You can buy adapters to convert the oil pan to AN fittings. I don't know about the tank. I assume you'd have to buy an aftermarket tank as is shown
Old Jun 5, 2014 | 04:06 PM
meanjoe's Avatar
meanjoe
Yeah but I love ZO6 bling!!
To Dry sump
