Button to start corvette
http://forums.corvetteforum.com/c6-c...many-pics.html
Also, if the car is a Manual trans 05, if it does not have the steering column lock eliminator now, then get it and install it when you reinstall the starter button. The 05 steering column lock is bad design, and just a problem waiting to happen.
When you snap the starter button back in to the bezel, make sure that both sides snap back in, and if they don't, then snap one side in first, then the other side (may have to do it twice if you snap the wrong side in first and the other side will not snap in secondly).
When you put the bezel back in to the dash, make sure that the temp sensor fan does not pop out of the bezel. To see if it popped out, just shine a light through the dash slots for it after you snap the bezel back in.
