headers
Old Jun 5, 2014 | 09:19 AM
walleyejack's Avatar
walleyejack
Default headers
searched the forum, but found no conclusive results, i have a chance at a used set of headers for my 08 base, they came off an 08 Z, will these ports match up the same? i see lots swithcing exhaust manifolds out from Z to Base, with not issues, am thinking this should not be an issue either.
Old Jun 5, 2014 | 10:18 AM
Unreal's Avatar
Unreal
They don't match, but can still work. Ls7 (z06) have D shaped ports, but they should still bolt on and work.
Old Jun 5, 2014 | 10:40 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Isn't the Z06 cross pipe (and axle back) 3 inches???
Old Jun 5, 2014 | 11:38 AM
Quick Silver Z
http://forums.corvetteforum.com/c6-t...rk-on-ls3.html
http://forums.corvetteforum.com/c6-t...-possible.html
Old Jun 5, 2014 | 11:53 AM
Unreal's Avatar
Unreal
Yes the xpipe will be full 3" so won't bolt to the mufflers, but that is super easy to fix/cut/weld, or just put a z06 muffler set/axle back on it.
Old Jun 5, 2014 | 12:14 PM
Quick Silver Z
Old Jun 5, 2014 | 02:19 PM
walleyejack
Originally Posted by Quick Silver Z
ya, i saw those threads, but mostly talking about Z factory manifolds on a LS3, not headers. i come to the conclusion they won t work, as the guy doesn t have the x pipe. so the headers will not hook up to my Y pipe more than likely.
thanks for the help.
Old Jun 5, 2014 | 03:56 PM
HOXXOH's Avatar
HOXXOH
The ports will match up fine with the D shaped LS3 heads. If the seller doesn't have the X or H pipe that match the headers, then just buy that part from the header manufacturer. That's the cheap part compared to the headers. If that part is available in a 2.5" outlet you're done. If it's only 3", then you can weld on a reducer near the back to match up with your over-the-axle pipes. Or you could use the 3" Z06 mufflers if you have a M6. They will fit on an A6 if you hammer a dent in the passenger side for clearance. The most power is using the 3" to 2.5" reducer and your current over-the-axle pipe welded into the Z06 muffler.
Old Jun 5, 2014 | 04:10 PM
walleyejack
yes, been doing more research, and even Arh, says the best power is 3" collector into 2.5" x pipe and out the back. i may just go with them, a lad a hour from me as headers, X pipe and 02 extensions maybe my best option $1000. with 3600 km on em, no, no shipping, no duty, no nutting.
To headers
