weird noise
Old Jun 8, 2014 | 01:26 AM
C6vettegfw's Avatar
C6vettegfw
Default weird noise
Hey guys a little while back my car was in the garage and my mechanic said I will need a new set of breaks after this summer. Its a 2006 ls2 manual. After that I was heating a bit of squealing from time to time when breaking. I also had the rear end noise and upgraded the diff fluid and done the figure 8s. Worked perfect. A few days ago I laid a little rubber and immediately the squealing got bad and I drove for about a min after.when I came to a stop the squealing was there followed by a weird grinding noise. I got out had a little look but couldnt see anything. The noise continued for a few more miles then went away. Any ideas guys what this is. Could it be a ROK or something in the wheel or is it just time to gt new breaks. What's everybody's opinion.
Old Jun 9, 2014 | 07:00 AM
Seadawg's Avatar
Seadawg
1st thing, learn how to use spell check, it's hard to even read your post. This isn't a text....
2nd, it's pretty easy to look at the edge of the pads, get a small mirror and maybe a flashlight, and you should see how much of the pad is left.
But if you trust your mechanic, go get your brakes serviced........
