Major trans/diff/coupler issue, need help!
Old Jun 19, 2014 | 10:09 PM
ACLR8R's Avatar
ACLR8R
Default Major trans/diff/coupler issue, need help!
Driving home from dinner, rolled into it in first and paddle shifted into second around 5k rpm and it popped and rev'd. Then sounds like rotational flopping. I thought I broke a half shaft or something.
Looked under the car and no sign of anything. Putting it into drive or reverse gives like winding type sound, not really grinding.
Haven't even put a full tank through the car since I got it, and now this!
Could it be the torque tube, or couplers? Just hoping its not a full trans build, or diff.
Old Jun 20, 2014 | 12:20 AM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Jack up the rear and try spinning each wheel while the car's still in park. If both wheels spin freely then you broke the output shaft in the transmission, if only one spins you likely broke a halfshaft.
Old Jun 20, 2014 | 08:54 AM
ACLR8R's Avatar
ACLR8R
Ok, I am going to have it towed to a shop and ill give that a try. Either way not good!
Is this common? The car only has a catback, so it isnt making crazy power.
Old Jun 20, 2014 | 09:37 AM
Jeremy@RPMTransmissions's Avatar
0Jeremy@RPMTransmissions
Former Vendor
Does it make the noise while the car is running while in park?
Old Jun 20, 2014 | 10:15 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Definitely not common unless you had wheelhop or something (which is common). Good luck and let us know what you find.
Old Jun 20, 2014 | 10:41 AM
ACLR8R's Avatar
ACLR8R
No noise in park or neutral.
No wheel hop, and traction control was on.
Old Jun 20, 2014 | 04:15 PM
ACLR8R's Avatar
ACLR8R
Well went to the parking lot where the car is, and it seems to be a half shaft down at the driverside wheel. Can spin the wheel in park, but the half shaft doesn't spin. Seems like its right down at the spindle.
Old Jun 20, 2014 | 04:33 PM
Former Vendor
It is common for the 05-08 C6 CV axles to twist off right after the outer spline. Replace the axles with C5 units and forget about it.
Old Jun 20, 2014 | 06:16 PM
ACLR8R's Avatar
ACLR8R
Yup, just ordered it!
Old Jun 21, 2014 | 09:50 AM
ACLR8R's Avatar
ACLR8R
Well, got it all put back together last night. Pretty straight forward, but it was 108 here yesterday which made it less than enjoyable
Seems like a fairly typical break, replaced it with a C5z which will hopefully stand up to my massive amount of stock with a catback horsepower!!!!
Old Jun 21, 2014 | 08:16 PM
Banditz's Avatar
Banditz
Looks like it was a good chance to wrench on the car at least. That part is fun, except for the being hot as can be outside!
Old Jun 22, 2014 | 09:03 AM
ACLR8R's Avatar
ACLR8R
Yeah, only had the car a couple weeks so it was good to get "acquainted". Just the not the best conditions. I did sweat out about 2lbs though
To Major trans/diff/coupler issue, need help!
